400 vs. 403
Old Dec 20, 2007 | 07:45 PM
GoldOlds's Avatar
400 vs. 403
In my search for a motor to give a mild build-up and replace my original 350 (I want to race the car once in awhile and not worry about blowing up the original engine), I've come across two recent classified ads; one for a 400 BBO and the other for a 403 SBO. The details:
400 ---> • out of a '68 442. • rebuilt less than 6,000 miles ago. • mild cam. • making the "original" 365 hp. $750.
403 ---> • out of a '79 Trans Am. • runs excellent. • has aluminum intake. • $350.
Any opinions on the better selection? I know about the 403's windowed mains, paper-thin cylinder walls, etc., but I like the idea of a shorter stroke and a motor that'll drop right in the car while breathing alright through the 2.25" exhaust. What would the 403's compression be if I put my #5 heads on it?
- GoldOlds
Old Dec 20, 2007 | 08:03 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Get that 403.
$350 is a steal, for a fine runner, with an alum intake.
Old Dec 20, 2007 | 08:43 PM
Redog's Avatar
I vote for the 400.
Rebuilt, and not windowed
Old Dec 20, 2007 | 08:47 PM
If the 400 has all of the proper papers, get it too
Old Dec 20, 2007 | 08:53 PM
Redog's Avatar
^^ I could have bought a 400 without carb, mani, exhaust manifolds and valve covers with the orginal tranny for $300, but it was too much work. The one I got was running, but I updated it (carb wise)
I guess it depends on your plans for the car your putting it in, if's it's just a cruiser, I'd say got for the cheap one, but why is it so cheap
Old Dec 21, 2007 | 04:53 AM
captjim's Avatar
The 403 will work fine, and as you say it bolts right in. Cr with the #5 heads should be around 8.5, but there are a lot of determining factors. That is a "late" 400, long stroke engine. The "early" 400s were screamers, short stroke, big bore. I would not go to the trouble of going the big block 400 in this case.
Old Dec 21, 2007 | 06:04 AM
Why don't you want to use the 350 that is in your car right now? SBO engines are pretty stout, you could build a screamer with the 350 and not have to spend the money on another engine.
Old Dec 21, 2007 | 09:49 AM
captjim's Avatar
^^^^^^ Agreed. What is the application and how fast are you looking to go??
Old Dec 21, 2007 | 11:13 AM
Oldsguy's Avatar
Past Administrator
I was thinking the same thing. For that matter, if you don't trust yourself to control the rpm's, you could always use an aftermarket ignition controler with a rev limiter.
Old Dec 21, 2007 | 01:35 PM
I'd go with the 403 as the long stroke, tiny bore 400 is not Oldsmobile's best design. I don't understand this comment however:
Originally Posted by GoldOlds
...but I like the idea of a shorter stroke and a motor that'll drop right in the car while breathing alright through the 2.25" exhaust....
- GoldOlds
Both engines will flow the same amount at the same RPM, so what difference does this make? If you're referring to the exhaust manifolds bolting up, the flanges on big blocks and small blocks are in the same position relative to the crank centerline (which is why W/Z manifolds won't fit a small block). Neither engine will breath adequately through 2.25" pipes.
Old Dec 22, 2007 | 10:50 AM
You won't have to worry about blowing up an Olds engine. Especially if you are just doing a mild streetable rebuild. If you start asking about hi compression pistons, solid lifter cam shafts, hi volume oil pumps, and double rolling timing chains then you should start worrying about blowing your engine. Not to say that double roller timing sets, and hi volume oil pumps aren't good additions to a streetable engine, even if they are overkill.
Old Dec 24, 2007 | 03:56 AM
GoldOlds's Avatar
I'm looking for something in the 13.5 to 13.9 range (1/4 mile) that's very streetable at the same time. The car ('69 Cutlass) has a TH350 w/ shift kit and 3.73:1 limited slip Chevy 12 bolt rear end. It'll be mostly for crusing, but it'll do the 1/4 mile 4 or 5 times per summer - or at least that's the plan.
- GoldOlds
BTW, thanks everyone for your input!
Old Dec 24, 2007 | 10:16 AM
captjim's Avatar
I'm with Olds64, build the 350. It is extremely durable, you have the best 350 Olds made, and you already have it. I run high 13s in a mild 9 to 1 355 wagon with 3.42 gears. Driven daily. Bump the Cr up to 9.8 or so, a little more cam, you already have the gears, 13.5s should be easy. Here is a link to my combo if you want the specs.
http://72.22.90.30/phpBB2/viewtopic.php?t=28012
Old Dec 24, 2007 | 04:39 PM
GoldOlds's Avatar
Again, thanks for the input! I guess this could be one of those cases where the solution may be sitting right under my nose (or should I say "hood") all along. When a set of SBO heads are milled, do I . . . A) have the pushrods shortened the exact same amount B) install roller tip rockers or C) both A and B?
Does anyone have any experience/opinions on the Edelbrock "Power Packages" (cam, lifters, intake, carb etc.)? I faintly recall someone saying some aftermarket cams work better for the SBO than others . . . which are they?
- GoldOlds
Old Dec 24, 2007 | 06:31 PM
captjim's Avatar
I personally don't like the E-brock grinds, they are just copies of old generic ones. Slow lazy-*ss ramps. There are a lot of better ones out there, IMO. As for pushrods, again IMO, rocker geometry is often overlooked. The best thing to do is assemble the engine using whatever valve train you decide on, and then get an adjustable pushrod. Use it to determine the proper length, then measure it and order 16 of them. Of course, this assumes the valve stem heights are all the same. Check this, http://www.cranecams.com/?show=faq&id=6
88hurstolds
Jan 20, 2020 11:39 AM
442mark
Jun 10, 2015 03:24 AM
Chris289
Feb 10, 2015 12:17 PM
sbFALL63
Jan 23, 2011 09:01 AM
sbFALL63
May 28, 2010 05:45 AM
