350 Rocket Engine Temp
Old Jul 3, 2004 | 02:33 PM
brent's Avatar
Question
I was wondering what is the normal operating temp on a 350 rocket engine. I have one that seems to be heating and i have put on a temp guage. What is the maximum temp i should be able to run at?
Old Sep 2, 2004 | 08:30 PM
PetChemMan's Avatar
Post
There are a lot of variables involved in judging whether your car is running too hot, but the bottom line is whether it boils over during the type of operation you give it. With a 50/50 mix of antifreeze/ water and a 12 to 15 psi radiator cap, you can run up to about 240 F before your coolant boils. In summer driving, if you can get the engine to maintain at least 190 F and no more than 220 F, you're doing fine. The most common causes of overheating are a bad thermostat, ( or one with too high a rating) , a blocked radiator, collapsed radiator hoses, bad viscous fan drive, slipping fan belt, or engine problems such as a blown head gasket or retarded ignition timing. Some aftermarket flex fans are inadequate, and electric fans can be worse yet.
DocAS
Jun 21, 2014 07:14 AM
54oldz
Jun 20, 2012 07:13 PM
Finn5033
Apr 10, 2012 09:23 AM
Emreozd
Feb 19, 2012 06:27 AM
OldsManNJ
Aug 6, 2010 12:58 PM
