What temp should 350 rocket run?
Old Aug 6, 2010 | 05:55 AM
OldsManNJ's Avatar
1971 Cutlass S
Hi all - I just got a 71 cutlass daily driver with a rebuilt 350 in it. Bottom half honed, rebuilt stock. Mild Edelbrock #3712 cam, lifters, #3711 intake & #1406 600cfm carb. I trust the shop who rebuilt the motor from what I hear about them, but it seems to run a bit hot to me. What temp should this run at at idle? at 70 on highway? I know all cars will be a bit different - I am just looking for a general idea.
This has brand new 3 row, not sure of thermostat - but at idle, or in heavy traffic - it runs steady at 200 on new autogauge meter. I was stuck in massive bumper to bumper traffic a week ago for almost 3 hours and it never moved off 200. At 70 on highway - it runs at about 205. Isn't this a bit high?
Could the thermostat be too high a temp unit, and getting a lower temp one would help it cool better? Will a 4 row make a big difference? Electric fans better?
Thanks to anyone who may respond - I do appreciatte it.
Old Aug 6, 2010 | 08:17 AM
Those temps aren't excessive. Keep in mind that at 15 psi, the boiling point of water is over 250 deg F.
Old Aug 6, 2010 | 12:58 PM
88 coupe's Avatar
Junior Member
........ it runs steady at 200 ........
It is where the '71 cooling system was designed to work.
If you replace your original stat with a 180, it should lower your temps to about 180° at the expense of defeating your emissions system.
Norm
shamusj
Mar 4, 2016 06:48 AM
oldrelics
Apr 16, 2014 09:40 PM
54oldz
Jun 20, 2012 07:13 PM
Emreozd
Feb 19, 2012 06:27 AM
brent
Sep 2, 2004 08:30 PM
