350 rocket
Old Jun 11, 2010 | 04:53 PM
Goofy's Avatar
350 rocket
I have a 1977 cutlass supreme brougham I want to restore, it has the 350 rocket in it. Going to send the engine away to be rebuilt to get 400 ponies out of her. The only thing I want to know is the block one of the better blocks cause of after 76 they were thinner. The car was built in late summer of 76 and the air breather lid has 350 rocket on it. Is this the thicker block, or how to find out?
Old Jun 11, 2010 | 05:25 PM
svnt442's Avatar
The block number is cast into the shelf behind the water pump. That will tell you what block you have. You can also look at the left cylinder head in front of the #1 spark plug for a large cast in number. If it's the later block it will have a large 3A. If you happen to have the early block (which I kinda doubt) it will be 8.
Old Jun 11, 2010 | 05:33 PM
Goofy's Avatar
Okay, thanks alot
Old Jun 11, 2010 | 06:06 PM
Goofy's Avatar
I looked, it has 3 A stamped. The car I bought for parts has an 8 stamped on it. So which one is worth the rebuild?
Old Jun 11, 2010 | 07:05 PM
It sounds like those are the casting marks on the cylinder heads. You need to get the casting number of the block, which is located above the water pump, by the oil fill tube. I can almost guarantee that this will have casting no. 557752, which is a thinwall, windowed main web block. The older blocks have solid main webs.
69OLDSCUTCONV
Feb 1, 2011 06:09 AM
cutlassKing
Nov 29, 2010 03:05 PM
gscott819
Jul 28, 2009 07:02 PM
esisson
May 22, 2008 07:47 PM
<Eddie>
Nov 1, 2005 07:30 PM
