350 plastic in the oil pan????
The only other things that get in there are pieces of valve guide seals. There are no other plastic wear pars other than the timing gear. Now another theory is... your timing set may have been changed once before with another nylon coated one and the pan was never dropped to clean the pickup.
Ok as i put those pieces together it turned out you guys were right....its a circle of teeth....My apologies and thank all of you who took the time out to give advice...Much appreciated
Oldsmobile Strong
Oldsmobile Strong
Cork or rubber work fine, just make sure both surfaces are clean and oil free. I like to use a thin coat of weatherstrp adhesive applied to the gasket and the pan. Let it skim over and then glue them together.
I thhink its time we cross that bridge just talked to a buddy of mine...His corvette had the same thing in his oil pan.....He pulled the heads and seen slight damage done....So now i really wanna take a peek inside just to see if things are good......he also had a 350 70s if not mistaken
Last time I bought a diesel op gasket I found after installing it that the motor mount could not be installed because the op gasket stuck out into its space. Other than that it was a great experience. Robust gasket. You may wish to trim excess before slathering sealer.
Pistons and how they look...
Just pulled the heads off my 69 olds 350.....Pistons look like lots of oil was getting in there the walls are clean no scrapes or anything.....But the tops of the pistons has lots of sludge or burnt build up on them.......any suggestions on to go from here are nice.
Unfortunately, Smitty is the guy who was selling the .011" thick shim head gaskets and not many would buy anything from him these days. I think Rocket Racing has the .028" thick composite head gaskets in stock once again.
You brought up you want to get to 380HP. You also stated due to lack of time and room you need to farm it out. If you have the money to invest, now is a good time to get in touch with a reputable builder and discuss your options and budget. I'm sure there is wear in the bottom end just due to age and mileage. In addition the heads probably ought to be sent out for a valve job. The engine itself looks fine from the pictures and probably a good foundation for what your after. I will add that 380HP won't come cheap, so be prepared.
Those pistons and heads look completely normal.
The clean one could conceivably have a slight head gasket leak, because when they're so clean, it usually means that water is getting in.
What was the compression on that cylinder?
Those are stock low compression pistons.
If the Probe 350 pistons are available, get a set with rings. Otherwise BTR Performance carries CP pistons with rings for $650. The CP are 4.065", so with .005" clearance, it needs to clean up at 4.070" with a hone. Or go with heavy Speed Pro forged or 400 sbc pistons and rods, which will be light and strong.
"might as well"
You realize that is like a $3000-4000 phrase here, right?
You realize that you CAN opt to just put it back together, with any head gaskets, and live with the power and compression you have?
Or, buy a motor out of a project/ parts car
I had my all-redone High Compression 403 with #6 heads up for sale for $1200 a while back. Drop in and go, or perhaps bump to larger intake valves first.
If you have $4k handy, discuss build options and prices with your local engine guy.
