350 olds high torque cams
![Thumbs up](https://classicoldsmobile.com/forums/images/icons/icon14.gif)
what do you guys recommend for a high torque cam---i had an old melling grind that worked well, but it was an old school lazy profile---what manufacturers have kept up with the times and developed modern cam profiles for the olds engines?
It’s not just the profiles but the right choice of duration, lsa etc.
Here's something with some duration with a big price tag
roller cam
https://www.summitracing.com/parts/c...ake/oldsmobile
roller cam
roller cam
roller cam
Two more with higher duration digging around longer. Not your low rpm range when jumping up high on duration.
https://www.summitracing.com/parts/l...ake/oldsmobile
Let's go over to jegs
https://www.jegs.com/i/Howards-Cams/...41-10/10002/-1
Found more in the 1200-5500rpm range
Cutlassefi did a 214/214 .472/.472 on a 110 LSA for my 9 to 1 Olds 350. Realize you need something better than the 1700 stall to give a good launch. I did 1/4 block burnouts with a 2300 flash stall with a 2004R. I went back to the TH350 with a stock converter. Coupled with the stock 2.78 gears, launch was far from exciting. I would say peak power was 2000 to 5000 rpm.
after seeing all these responses about radical cams, i realized i forgot to say what car this 350 is in...72 delta 88 convertible---4500+ lbs and a 3.23 gear. thats why i am looking for a low rpm TORQUE cam
64CutlassConvertible
June 19th, 2019 03:52 AM
import extermination
October 10th, 2011 03:55 AM
