350 olds high torque cams
Old Mar 7, 2020 | 10:44 AM
timrocket72's Avatar
Thumbs up 350 olds high torque cams
what do you guys recommend for a high torque cam---i had an old melling grind that worked well, but it was an old school lazy profile---what manufacturers have kept up with the times and developed modern cam profiles for the olds engines?
Old Mar 7, 2020 | 01:00 PM
cutlassefi's Avatar
It’s not just the profiles but the right choice of duration, lsa etc.
Old Mar 7, 2020 | 01:17 PM
Letsrunum's Avatar
There was only one cam I found better than mine in 07 at 2500-6300rpm vs 1800-6200(both non roller cams). Companies making anything better these days?
For comparison
Old Mar 7, 2020 | 01:41 PM
cutlassefi's Avatar
How do you know it would’ve been better?
Old Mar 7, 2020 | 01:45 PM
Letsrunum's Avatar
I was going off it had more lift than mine. If I remember correctly(it was many years ago).
Old Mar 7, 2020 | 01:54 PM
Letsrunum's Avatar
Here's something with some duration with a big price tag
roller cam
https://www.summitracing.com/parts/c...ake/oldsmobile
Old Mar 7, 2020 | 02:04 PM
cutlassefi's Avatar
roller cam
Apples to Oranges though. I sell roller cam kits for $900.00, shipped
Whoa whoa whoa....low rpm high torque is what i need. Idle to 4500 or so....
Old Mar 7, 2020 | 02:10 PM
Letsrunum's Avatar
I agree. It wasn't much more than mine at between 4-5 times the price of mine.
Old Mar 7, 2020 | 03:17 PM
cutlassefi's Avatar
Single pattern cam in the mid teens@.050 would do well.
Old Mar 7, 2020 | 03:55 PM
Letsrunum's Avatar
Two more with higher duration digging around longer. Not your low rpm range when jumping up high on duration.
https://www.summitracing.com/parts/l...ake/oldsmobile
Old Mar 7, 2020 | 04:43 PM
cutlassefi's Avatar
So why are you posting it?
Old Mar 7, 2020 | 05:23 PM
Letsrunum's Avatar
Lower your duration and you will probably find some cams to post on here.
Old Mar 7, 2020 | 05:40 PM
Letsrunum's Avatar
https://www.summitracing.com/parts/h...ake/oldsmobile
More in the 1300-5500rpm range
Old Mar 7, 2020 | 06:11 PM
Letsrunum's Avatar
Let's go over to jegs
https://www.jegs.com/i/Howards-Cams/...41-10/10002/-1
Found more in the 1200-5500rpm range
Old Mar 10, 2020 | 02:08 AM
AZ520's Avatar
Good daily ripper cam:
https://www.lunatipower.com/voodoo-h...8-256-262.html
Old Mar 10, 2020 | 08:47 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Cutlassefi did a 214/214 .472/.472 on a 110 LSA for my 9 to 1 Olds 350. Realize you need something better than the 1700 stall to give a good launch. I did 1/4 block burnouts with a 2300 flash stall with a 2004R. I went back to the TH350 with a stock converter. Coupled with the stock 2.78 gears, launch was far from exciting. I would say peak power was 2000 to 5000 rpm.
Old Mar 10, 2020 | 07:39 PM
coppercutlass's Avatar
Chevy budget Olds powered
I ran a Comp 260 H in a near stock 350. Car ran 13.8's through the mufflers in the 1/4 mile.
Old Mar 11, 2020 | 11:40 AM
after seeing all these responses about radical cams, i realized i forgot to say what car this 350 is in...72 delta 88 convertible---4500+ lbs and a 3.23 gear. thats why i am looking for a low rpm TORQUE cam
Old Mar 11, 2020 | 12:35 PM
The 260h is pretty much a towing cam fwiw
64CutlassConvertible
Jun 19, 2019 03:52 AM
quentinnw2
Oct 14, 2013 02:46 PM
quentinnw2
Oct 13, 2013 07:19 PM
Oldwolf
May 28, 2013 05:10 AM
import extermination
Oct 10, 2011 03:55 AM
