350 Hesitates
350 Hesitates
350-4. Idles nice. Big hesistation on throttle, then either dies, or RPM goes up and also runs smooth. Seems starved for fuel. Please advise if it is more likely fuel pump or carb, or please make suggestions. Thanks much. Paul
Oldcutlass is right could be a lot of other things causing this problem. You also need to be a little more specific as to when these problems occur to get any good advice.
BUT, all of the above being completely correct, and needing to have been said, if it IS your carburetor, sounds like a bad accelerator pump or maybe blocked transition ports.
