350 Hesitates
Old Aug 12, 2011 | 12:57 PM
PaulDan's Avatar
350 Hesitates
350-4. Idles nice. Big hesistation on throttle, then either dies, or RPM goes up and also runs smooth. Seems starved for fuel. Please advise if it is more likely fuel pump or carb, or please make suggestions. Thanks much. Paul
Old Aug 12, 2011 | 03:10 PM
Have you done anything recently to it?? Does it have points or electronic ignition, Is your dwell/timing correct, vacuum leaks? Is your vacuum adv. working properly? It may not be a carb issue!
Old Aug 12, 2011 | 03:18 PM
jag1886's Avatar
Oldcutlass is right could be a lot of other things causing this problem. You also need to be a little more specific as to when these problems occur to get any good advice.
Old Aug 12, 2011 | 03:29 PM
BUT, all of the above being completely correct, and needing to have been said, if it IS your carburetor, sounds like a bad accelerator pump or maybe blocked transition ports.
Dead Reckon
May 25, 2015 07:22 PM
Miles71
Aug 20, 2012 06:16 AM
dharlett
Sep 23, 2009 03:30 PM
SX455
Jul 6, 2007 10:42 AM
<Eddie>
Nov 1, 2005 07:30 PM
