350 heads on 330
350 heads on 330
Hey guys,Can I put 350 heads on my 330 so I have the newer rocker arm setup? I need a rocker for my 330 but am having no luck finding any. So my other option is to change my heads. Will this work
Yes the 350 heads will bolt up just fine. I believe they have a larger combustion chamber, so that may reduce your compression some. I've got extra heads from several years and am sure there's other members here with extras. Would you post your location? Maybe you can save some shipping $$ by getting the closest ones John
Aparently Kanter has them.
MD Rocker arm assbly (early 64 - cast arms) (16) $195.00ea
http://www.kanter.com/p20-oln.html
