350 headers for 84 b body/c body
I’m swappin a 350 into my 84 98 coupe which headers would work the best g body headers or a body headers? since they don’t make anything for these cars specifically
Try a set of the Chinese full length stainless off Ebay. Surprisingly I had to do mods on the 70S, another guy put them in with 0 issues on his G body. Very well made and cheap.
I have full-length Hedman Hedders on my 71 98. They fit well but are a PITA to install and maintain. I recommend against installing headers. If you have to use A or G body headers then make sure you have a BFH handy to get them to fit.
The 1977-1985 full size cars use a frame that is VERY similar to the frame under the 1973-77 A-body cars. The full size DO use a bolt-on frame stiffener behind the control arm locations that will likely interfere with headers. Personally I would hesitate to remove it since GM is not in the habit of increasing production costs by installing unneeded parts.
So y’all are sayin I’d probably be better off stickin with exhaust manifolds?
Are the ones from the 307 any different than the 350 besides that they have tht oxygen sensor?
As noted before, you'll have to remove the braces going from the cradle to the frame rail.
https://www.summitracing.com/parts/h...hoCQ2MQAvD_BwE
if i ran these headman shortys would I still have to remove the frame brace? I been removing the 307 and while I was under the car it seems like these would dump out in the same place the factory manifolds
Go to the Hedman site and take the header dimensions down. The Hedman are a mid length header and you may be close to the ground, even with a tight bend. The other two options are Sanderson shorties, very similar but 1 5/8" tubes, much thicker 3/8" flange that only requires RTV. The collector is much shorter and gives good ground clearance. In mild steel and ceramic coated, more money to buy. I have used multiple sets, quality is hit and miss. The third choice is Thornton shorties. In stainless, a thicker flange like the Sanderson and bolt to existing A body down pipes. There is one flattened pipe and quality is also hit and miss. Good luck.
