350" headers in 64 body?
Old May 15, 2010 | 06:45 AM
Svinet's Avatar
F-85 Cutlass Coupe owner
Hey guys
I have a 64 F-85 Cutlass with a 350 '68 engine. Which headers will I able to fit with the 64 A body ?
Thanks in advance!
Old May 15, 2010 | 12:12 PM
64Rocket's Avatar
I have another '64 Cutlass that I put a 350 OLDS in it. I had to move the engine back a little over an inch to make the headers fit. I had to work the header tubes in a few spots also. I roam the wrecking yard to find a drive shaft of the right length and everything else is good to go.
Gene
Old May 15, 2010 | 07:08 PM
Gene
Wow! Those must have been some headers!
For the O.P., the 350 is externally identical to the 330 that was factory installed in that car. Unfortunately, the 64-67 frame rails are a little narrower than those on the 68-72 cars, and since the early cars are less popular, most header manufacturers have dropped those headers from their catalogs. SOME -and I stress the word some - 68-72 headers do fit the early chassis, but it's hit-or-miss, depending on how the manufacturer chose to route particular tubes. Headers from different manufacturers are not the same size or shape.
Old May 16, 2010 | 04:22 AM
Svinet's Avatar
Thanks! So I guess its a bit of a gamble eh?
Based on that info I better go with the smallest tubes I can find?
Old May 16, 2010 | 07:44 PM
Not necessarily. The problem isn't only the tube diameter, it's the exact routing that a particular manufacturer has chosen.
Old May 17, 2010 | 08:09 AM
Svinet's Avatar
Okay. I better stick to other people experiences with this. Returning a set of headers from Europe to the US isn't exactly cheap.
64rocket, which brand of headers did you go with? Do you have any pictures of your setup?
Thanks guys!
Old May 17, 2010 | 08:15 PM
64Rocket's Avatar
I used "Headman" headers. I will get some pic's tomorrow.
Gene
Old May 17, 2010 | 11:22 PM
Svinet's Avatar
All right. Thanks man!
72OldsRocket
Nov 27, 2011 06:56 AM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
WTony
Jul 3, 2010 02:16 PM
