pistons
Old May 17, 2010 | 07:58 AM
cbeatty's Avatar
pistons
I am wondering what the differance is in a 1970 350 buick, and oldsmobile piston is. If i recall the buick piston had a nut in the center of it. It was a 4 bl. had dished piston's.made a lot of power!Is it because the buick heads had more of a closed chamber? I dont know what the comp.was. I think the dist was in the front! Long time ago.
Old May 17, 2010 | 01:29 PM
cutlassefi's Avatar
Not remotely the same and in my opinion the Olds is a better performing engine.
Old May 17, 2010 | 02:38 PM
Warhead's Avatar
Buick 350 has a 3.800 in bore, I am not sure what size valves. I have done a set or 2 of these, but they have issues with cracking the cylinder heads on the top side of the head (valve cover side).
Olds 350 has a 4.057 bore with a 1.875 intake, or a 1.995 intake valve.
The piston was nut free, the nut was behind the wheel.
Jim
Old May 18, 2010 | 10:34 AM
cbeatty's Avatar
reply
I didnt build the thing! It had been into before I got it. The head did crack, We took it off to ck it.Three people saw the pistons.No drugs or drunking. I havent seen anything like it since.I have worked on farm tractors in the past,seen some crazy things! I am getting flat tops for the 350. Dont want to race, just get the spot I want when on the highway.No offence taken on the nut statment.
Old May 18, 2010 | 11:52 AM
cutlassefi's Avatar
It's not a nut but a large button used to locate the piston during grinding. They are cast pistons, don't think Buick used anything but that piston.
True most Oldsmobile owners are a nut behind the wheel, why else would we do this?
Old May 18, 2010 | 04:49 PM
Warhead's Avatar
Good, I was only kidding.
But about the drugs, or drunking...
Jim
72 Supreme
May 20, 2008 04:06 PM
Olds71suprema
May 10, 2008 09:44 AM
77omega
May 9, 2008 07:25 PM
Big J
Apr 21, 2007 08:31 PM
VanZant
Aug 7, 2004 03:44 PM
