350 head question
Old Sep 8, 2024 | 06:52 PM
Mr.Classic's Avatar
350 head question
I was wondering if anyone could help? I have a 1971 Olds 350 2 barrel stock. I was thinking of getting #6 heads and having them redone and install on the motor with a new intake and 4 barrel with HEI. Would this help and increase my compression for better HP ?
Old Sep 8, 2024 | 07:29 PM
No, the 6 heads have the same combustion chamber size as the 7 heads so no difference in compression or flow rate. FYI, the 5, 6, 7, and 7a heads all have similar chamber volume and flow rate.
Also the HEI will not increase power, it will just remove the maintenance of points.
Old Sep 9, 2024 | 05:00 AM
cutlassefi's Avatar
Old Sep 9, 2024 | 06:28 AM
Sugar Bear's Avatar
Do a compression test or even better a leak down test to determine the condition of the engine in general. Check the timing chain and gears.
Adding a 4bbl and dual exhaust will increase the fun factor and add a little performance. I personally wouldn't bother with HEI if what you have is working well.
Old Sep 9, 2024 | 01:25 PM
Adding a 4bbl and dual exhaust will increase the fun factor and add a little performance. ​​​​​
Yep. The 1971 and 1972 engines were essentially the same, with the following power ratings (SAE NET specs):
These are the 1972 numbers that are broken out by carburetor and exhaust, whereas the 1971 specs just show the dual exhaust 4bbl with both GROSS and NET numbers.
GROSS = 260 HP
NET = 200 HP
72OldsCut<
Oct 31, 2022 11:20 AM
oktay1811
Jul 21, 2016 05:08 PM
highschoololds
May 5, 2012 11:13 AM
71olds
Sep 27, 2010 07:06 AM
74omega
Jun 15, 2008 06:28 PM
