Need help 350smb
Need help 350smb
I just bougt a 350 cutlass engine 1971 with 5 heads .i searched on internet one say it has 180hp another one say 240 . Can somebody help me what it is
71 olds cutlass 350 2bbl engine .the heads are from 69 5 heads .
Regards .oktay
Regards .oktay
So thnx for the fast reply . The heads are at the moment at the shop for restoration .what can i do more to get 300-350 hp out of it ,
Sorry for my bad english .im from holland
Regards oktay
Regards oktay
Get rid of the big dish pistons and use the 6 cc dish forging like a 68-70 310 rated engine , a decent cam , headers and rpm intake of you want 350 plus. The stock 325 rated W31 with its hotter setup is more of a 350-360 hp engine actually but needs gears and octane
XE cams I would not use one, they are too aggressive of ramping and hard on valve-train harmonics , these have been known to have lifter issues at above 5000 rpm and nose over in some case, more seat pressure was a crutch to fight against it (lifter crash). These can make strong torque but may also ping on you if too small a grind and from the high cylinder pressure created.
If you want a Comp Cam the older Dual Energy series 275 DEH cam is something that would work well. I still want to try one later. It is made to help crutch the weak exhaust to intake flow ratio of a stock Olds engine. its like 219/233 at 050
Mark on here Cutlassefi is great resource and a dealer of Erson cams too and he has a TQ40 220/228 grind that would rock a nice 355 Olds with those #5 heads and the 5.8 cc pistons.
headers yes
RPM intake yes
original valves hell no
minimum of a bump up to 2.00/1.625 like a W31 but honestly why bother just go for the 2.07/1.71(1.68) SS valves on Ebay. They fit and just have the bowls blended in after they cut to the bigger seats. The Olds has a big enough bore to handle those valves.
Change to studs and guide plates too so you can adjust the valves like a normal engine too
minimum of Hughes BOP HD 2400-2600 12" converter
and at least a 3.08-3.42 gear , no 2.56 or 2.78 stuff.
Top it off with a Cliff Ruggles built Quadrajet or equivilent with a open element air cleaner , a 160-180 T stat depending on where and when you drive and your distributer gone thru with advance springs lighter to bring in total sooner.
your welcome , good luck. Main thing is above all things never use the "replacement " cast dish pistons from a regular auto re-builder. The compression ratio is way too low just as you would never ever use a re-builder provided "stock" Olds camshaft. They are super tiny 187/200 @ 050. This is why some give a stock 350 Olds a bad reputation for being slow and jump to a 455 or a LS swap. Car has no compression, no cam and often 2.56 gears
NOS is not my style but some love it. Takes a smart tune and setup to be reliable
