350 Crank seal install depth
Any mechanics know the correct depth to install the front crankshaft seal into the timing cover? Should it be flush with the cover or installed to the bottom of the radius on the cover, or to some other depth?
My old seal is underflush, set to about the bottom of the radius....so I was planning to set the depth of the new seal to the same depth (underflush, to about the bottom of the radius. Should the seals be set flush or underflush?.
I don't think anyone pays much attention to this. The surface of the balancer that the seal rides on is smooth, and has no particular spot where the seal is supposed to ride (though if it's worn, you may need to sleeve it).
The CSM says,
The picture shows absolutely nothing of practical value.
I just whack it in with a socket.
The CSM says,
- Apply 1050026 Sealer or equivalent to outside diameter of seal.
- Using Tool BT-6405, install oil seal as shown in Fig. 6B-158.
The CSM says,
The CSM says,
cite CSM chapter and verse [which I was about to do myself]
followed by "Aw hell, boy, just cram it in there good-n-tight, the 'zact location don't matter none!"
Flush
Id say a new surface to run against would give u a better seal. The pulley will sit in the original location. Just what id do
2blu442
November 12th, 2009 08:03 PM
