350 Cam installation
You may or may not have enough room for the camshaft to fit into the front of the block without moving the condenser but if you damage it, how much will it cost to repair/replace it? What you may be able to do is remove enough of the front of the vehicle to move the condenser farther away from the engine without breaking the A/C lines. I have done this on two vehicles in the past but they were not a '71 Cutlass, so YMMV!
I swapped cams in my car a few times.
Yes, the AC condenser needs to be moved out of the way. I unbolt it, then swing it to the passengers side and tie it to keep it out of the way.
That's all I do - the grille and other items stay in place.
