350 build questions
here is my complete build.
355 Olds in my 72 cutlass
10 to 1 compression speed pro flat tops
lunati voodoo cam 522/539 lift 233/241 duration @ .050 lift
Prw roller tip rocker (7) and one comp cams roller tip rocker
Pro gear timing chain
#6 heads done by rocket racing just bowl work 2.07 in. 1.63 ex.
full length headers ,x pipe
34 degrees of timing on 93 octane
edelbrock performer rpm intake
holley 3310 750 cfm carb box stock
proform hei dist
crank is .010/.010, bore is .030 over bored with a tq. plate , it was balanced
Engine built by me
backed by a th350 Built by me ebay 3000 stall converter and 3.73 gears out back
Runs 12.60's @ 105mph in the 1/4 mile
proform hei dist
Engine built by me
wildwillie1981
April 24th, 2013 04:19 PM
