350 build questions
Old Dec 30, 2015 | 05:25 PM
Kyron219's Avatar
350 build questions
Hey i have a 69 350 and looking to get about 375-400hp would that be alot of wear and tear????
Old Dec 30, 2015 | 05:47 PM
coppercutlass's Avatar
Chevy budget Olds powered
I'm making appx 380 ish and I been beating the tar our of it and it's a pretty plain build.
Old Dec 30, 2015 | 06:01 PM
Kyron219's Avatar
Ok was just asking..heard alot about engine wear from high hp builds....Also what are somethings at i should change to achieve about 375 hp
Old Dec 30, 2015 | 06:13 PM
Kyron219's Avatar
Ok what are some things i can do to accomplish this build cam intake etc..
Old Dec 30, 2015 | 06:22 PM
Kyron219's Avatar
Everything is stock except intake ebrock 7111 and carb 1407
here is my complete build.
355 Olds in my 72 cutlass
10 to 1 compression speed pro flat tops
lunati voodoo cam 522/539 lift 233/241 duration @ .050 lift
Prw roller tip rocker (7) and one comp cams roller tip rocker
Pro gear timing chain
#6 heads done by rocket racing just bowl work 2.07 in. 1.63 ex.
full length headers ,x pipe
34 degrees of timing on 93 octane
edelbrock performer rpm intake
holley 3310 750 cfm carb box stock
proform hei dist
crank is .010/.010, bore is .030 over bored with a tq. plate , it was balanced
Engine built by me
backed by a th350 Built by me ebay 3000 stall converter and 3.73 gears out back
Runs 12.60's @ 105mph in the 1/4 mile
Old Dec 30, 2015 | 07:17 PM
I moved your posts to your own thread, good luck with your build.
wildwillie1981
Apr 24, 2013 04:19 PM
Jrod
Jan 4, 2013 09:18 AM
Indy_68_S
Dec 15, 2012 09:39 PM
69350rocket
Nov 26, 2011 01:40 AM
69 442 protour
Dec 9, 2006 09:25 PM
