330 rebuild
Old Nov 22, 2011 | 06:49 PM
optimus's Avatar
330 rebuild
hello everyone i need some help i am deciding wether or not to rebuild my olds 330 would it be worth it or should i get another motor any help would be appreciated thanks
Old Nov 22, 2011 | 07:04 PM
Rickman48's Avatar
Any Olds motor will cost about the same to build - cores are anywhere from $100 - $600, whether it be 350 or 455.
What are your intensions??
Old Nov 22, 2011 | 09:32 PM
Redog's Avatar
The 330 is a pretty nice motor, if you have the hi compression "4" heads it has 10.25:1 CR right out of the box.
I like the 330 and the 425. They are "odd ball" engines in everybody's eyes, but still make a lot of power if built right, just like a 350 or 455. Plus they fall into that 1964-1990 all exteranlly the same statement, but the 64 330 has the timing tab on the wrong side.
The trick is finding overbore pistons for the 330. I can't find them anywhere
Old Nov 23, 2011 | 07:16 PM
optimus's Avatar
330 rebuild
ok so there were 2 different 330 or is the 330 a high compression motor and how do i tell if it is a high compression 330
Old Nov 24, 2011 | 11:23 AM
Generally the Hi-comp came with a factory 4V carb. Basically you need to consider what you want out of your car. Originality, performance, or what are you after? Then you need to consider your budget. How much are you going to spend?
Old Nov 24, 2011 | 11:59 AM
tru-blue 442's Avatar
Old School Olds
Just my .02. I had a 67 cutlass with the # 4 heads and a 4-speed
with a 4 bbl from an old toronado. Damn, that thing would haul...
Old Nov 27, 2011 | 04:18 PM
goatwgn's Avatar
330's are good engines. You might actually have to lower the CR a little bit (to about 9.2 to one) to use pump gas. My Stepdad had a '65 F85 with a "built" 330 back in the late '60s/early '70s that ran 12's consistently.
Old Nov 28, 2011 | 06:58 AM
Have you tried EGGE for the pistons?? L2228-8 - PISTON SET
http://www.egge.com/site/?d=48&dt=1&...SMOBILE&rpp=10
Old Nov 28, 2011 | 05:42 PM
optimus's Avatar
330 rebuild
are those pistons pretty good then i have never used that manufacture
Old Nov 29, 2011 | 06:44 AM
Others have used them with no real problems. There may be other venders, just wait and some of the others will chime in. The 330 can be bored up to .060 over, ask your machine shop if they have any sources.
Old Nov 29, 2011 | 10:26 PM
Redog's Avatar
High compression 330 will have "WG" on the rim of the head
Old Nov 30, 2011 | 09:14 AM
Boldsmobile's Avatar
What year 330?
Old Nov 30, 2011 | 09:51 AM
I believe his is a early 67! We never verified what engine is in it from his newbie post. He has an F-85.
jensenracing77
Jan 12, 2016 02:02 PM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
jessejames
Mar 20, 2009 08:01 PM
