330 Electronic ignition
Going to convert my 67 330 olds to electronic ignition. Cost is not much of a factor. Also I want to change the dist. anyhow because it is on the engine stand with oil pan and pump off to fix rear main seal. So what is the best option for a conversion?
Keep in mind that despite the magazine articles (where they are trying to push the products sold by their advertisers), an electronic ignition system will not provide any performance difference over a points ignition that is properly maintained. People who claim a big difference are typically comparing badly pitted points and an old cap and rotor with brand new parts in the electronic distributor.
I've converted most of my cars only because I'm lazy.
Not looking for performance upgrade just ease of use. Lots of options out there just trying to figure out the best one. Looked at Pertronix but have heard good and bad. Some problems with Tach ? Summit has a stand alone unit but doesn't really have a brand name ? Maybe Accel? I currently don't have a coil for the 330. Also if I have to pull the dist. to shim the Pertronix shouldn't I just replace it ?
Although most have trouble free service with Pertronix, personally I'd choose points. For the amount of miles you are probably driving a year you will have to change once every 3 years or so. Reliability of points is better over electronics any day. Points only takes 30 minutes to change and 10 to periodically check and adjust. You can change a lot of points and condensers for what the Pertronix costs. As with any ignition system, make sure you use good quality parts.
I'm in Canada, but I will throw this out ther if interested.
I have an HEI out of my 1976 Olds 350. Has accel coil (acc-140005), Summit cap/rotor (Sum-G5237) Morosso curve kit set-up for mild 350
All parts have about 300 miles on them ready to run
I swapped my Distributor out for the DUI unit so I won't be needing the original one.
Eric
Eric you know I will argue about points being more reliable than electronics. Points get pitted and have to be replaced or filed (I still have a point file) and re-gapped. I think one of the biggest problems with points is being able to fund a decent set that is not made in China.
I have a Summit HEI in my 71 Olds 98 with a 455 and while it works ok I've actually been thinking of changing back to a points distributor and possibly adding a Pertronix kit for reliability and easy starting. I really think I can dial in my timing better by going back the OE distributor.
This coming from the guy that buys parts from a catalog because Summit and Jegs say so.
Jen
May 23rd, 2012 10:44 AM
atkinsom
November 21st, 2011 09:40 AM
