324 needs rebuild
Old Feb 19, 2026 | 01:43 PM
tbsingleton1's Avatar
Unhappy 324 needs rebuild
Took my '55 88 Holiday in for head gaskets. Mechanic says the engine needs to be rebuilt. Should I rebuild the original 324 or go with another option? Would love to stay "Rocket".
Old Feb 19, 2026 | 05:57 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Was the power adequate? You could bump compression and the cam size somewhat, depending on what manners you want. There are some differences between the size and years of the original Rocket V8. You know the original engine will fit along with all accessories.
Old Feb 19, 2026 | 06:16 PM
Sugar Bear's Avatar
Why does it need to be rebuilt? I would keep it original.
Old Feb 19, 2026 | 09:01 PM
Charlie Jones's Avatar
Phantom Phixer
If you're going to re-build it, bore it out to 4 in. and use 1957 371 pistons.
It will make it a 346 and should give that '55 all the power it needs.
Old Feb 19, 2026 | 11:21 PM
OLDSter Ralph's Avatar
Where are you located ?
What made you decide the engine needed head gaskets ?
Old Feb 20, 2026 | 03:08 AM
Make sure you get a compression test done before deciding to rebuild the engine. Better yet, a cylinder leak down test will tell you exactly what the engine is doing. You can rent a compression gauge from your local auto parts store (and maybe even a leak down tester) if you want to do the work yourself.
Old Feb 20, 2026 | 09:20 AM
Sugar Bear's Avatar
Curious, is a 371 crank fit a drop in along with the 4" bore to make a 371?
Old Feb 20, 2026 | 07:05 PM
Phantom Phixer
No. the block deck height was raised in 1957 for the 371.
But the pin to crown height remained the same.
Olds cylinder walls are very thick and can be bored out a lot.
22 cubic inches and about a point more compression plus a cam. Will make that 324 snarl.
54Rocket
Jun 2, 2022 07:15 AM
WyldWilly
Apr 28, 2022 06:18 PM
oral
Jul 6, 2021 08:46 AM
kaptmikey
Nov 27, 2012 10:49 AM
gdarty74
Oct 11, 2008 02:23 PM
