324 ballast resistor
Old May 2nd, 2012, 06:12 PM
Rocket331's Avatar
Can anyone tell me the acceptable voltage range on the coil side of the ballast resistor when the ignition switch is in the 'run' position?
Rocket331 is offline
Old May 2nd, 2012, 08:49 PM
Highwayman's Avatar
5-7 volts with points closed. Battery voltage with points open.
Source: 1956 shop manual.
Highwayman is offline
Old May 2nd, 2012, 08:52 PM
Rocket331's Avatar
Thank you!
Thanks, Highwayman! I took it apart and found a loose connection. All fixed and the engine runs.
Old May 2nd, 2012, 10:07 PM
Highwayman's Avatar
I love a happy ending!
ChefDeadpool
December 9th, 2011 04:38 PM
wolskara
September 10th, 2010 08:06 AM
tpawlik
February 5th, 2010 02:38 PM
NikkiLee
March 22nd, 2009 04:27 PM
dan2286
February 5th, 2009 06:42 PM
Quick Reply: 324 ballast resistor
