307 y vin timing adjustment
Old Feb 27, 2017 | 05:07 PM
deltsanddueces's Avatar
can someone run me through the process of adjusting the timing on one of these 80's computer controlled distributors, I know I have to ground the computer but I don't know what to unplug
Old Feb 27, 2017 | 05:41 PM
BillK's Avatar
Exactly what year and what car ?
Old Feb 27, 2017 | 05:46 PM
85 delta 88
Old Feb 28, 2017 | 10:33 AM
SEARCH is your friend:
https://classicoldsmobile.com/forums...djustment.html
Bottom line is that you don't disconnect anything. You simply jumper the A and B terminals in the ALDL connector to ground the diagnostic lead.
Old Mar 1, 2017 | 08:04 AM
might be a stupid question but where is the ALDL connector located
Old Mar 1, 2017 | 08:36 AM
Under the dash, below the steering column.
Old Mar 1, 2017 | 08:39 AM
If you plan to do any work on this car, get a set of these. There are many on ebay right now, with prices under $20.
Old Mar 1, 2017 | 03:17 PM
BlackGold's Avatar
On the G-bodies it's closer to the center of the dash. Is it really under the steering column for the Delta 88?
Old Mar 1, 2017 | 03:28 PM
Yep.
Old Apr 14, 2017 | 12:09 PM
Yep.
Is the timing supposed to be at 20 degrees btdc with the test lead grounded or is it supposed to be at 20 degrees without the test lead ground,
Old Apr 15, 2017 | 09:48 AM
Did you read the link back in Post #4 or the CSM?
In any case, here's a little common sense: The computer is constantly varying the timing based on multiple sensor conditions. If you try to set the timing with the computer active, it will continue to vary the timing while you are setting it, meaning you will NEVER get an accurate initial timing set. Jumpering the ALDL connector as described above locks out the computer so you can set the timing properly.
Old Apr 15, 2017 | 12:26 PM
Ah ok I gotcha, thanks Joe
70-442-W30
Aug 10, 2016 04:38 PM
kanek4
May 28, 2014 05:41 PM
bdub217
Jul 18, 2012 10:35 AM
Rob delta
Apr 24, 2012 07:38 PM
442scotty
May 13, 2009 05:42 PM
