307 Vin 9 85 delta 88
Old Jul 17, 2012 | 11:11 AM
bdub217's Avatar
Kickin' It Oldschool
2nd owner of a 85 delta 88 with 6a heads, 107k original miles, cat delete with 2 1/2" pipe to flowmaster 40 series dumped before rear axle, cai, mild cam upgrade.....
What rear end will bolt into this thing directly? I dont mind a bit sticking out on sides of car, also I'm wanting a gear ratio of 3:23-3:42. Posi would be nice but not needed.
EDIT: i have the TH2004r tranny with OD.
Thanks in advance!
Old Jul 17, 2012 | 11:14 AM
coppercutlass's Avatar
Chevy budget Olds powered
The rear end out of any b body gm would fit. like impala ss etc etc. they had 3.42 gears stock if i remember right
Old Jul 17, 2012 | 11:15 AM
bdub217's Avatar
quick response, also would that be an 8.5 inch 10bolt instead of the 7.5 i have now?
Old Jul 17, 2012 | 11:58 AM
Redog's Avatar
Anything rear from a 73-77 A Body will bolt right up too, but you'll more than likey have to chage the gear. Most common is like 2.41 or2.56,
The are 28 spline unlike 30 spine in the 91-96 B Bodies, however 91-96 has the 5x5 bolt pattern
Old Jul 17, 2012 | 01:12 PM
Redog brings up a good point I forgot the 5x5 bolt pattern. You will need diffrent wheels.
Old Jul 17, 2012 | 04:32 PM
bdub217's Avatar
im okay with getting a 5x5 lug wheel and slapping my tires on them =) that's not a big deal. Now i dont want to mess with gears other than cleaning them and filling the fluid back up with fresh and then bolt it into the driveshaft and frame. If i have to mess with gears i might as well just buy a new ring and pinion in the ratio i want for my 7.5inch 10bolt 4 3/4 i currently have. I'm at a ratio of 2:78 atm and i do not like the sluggish acceleration, its not that bad, but it would love some 3:23 or 3:42 gears .......
ANd if i go with a 91+ model rear end out of say a old cop car caprice is my only issue bolting the driveshaft into the differential housing and changing wheels to 5x5 bolt pattern? or is there more to it than that?
Old Jul 18, 2012 | 08:33 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Where in Illinois are you? I have a few good 8.5s here. Don't bother with the 7.5. they are garbage.
Old Jul 18, 2012 | 09:25 AM
If you find a rear end from an impala ss they have stock 3.42 gears.
Old Jul 18, 2012 | 09:29 AM
bdub217's Avatar
Champaign area couple hours south of chi town.
Old Jul 18, 2012 | 10:35 AM
bdub217's Avatar
Would love to do that in my 4 door sled! =0 droool.........
excuse me while I kiss the sky.....
tcturner
May 15, 2015 12:51 AM
kanek4
May 28, 2014 05:41 PM
Lars
Feb 1, 2014 09:07 PM
carbonf00tprint
Nov 4, 2012 07:53 AM
