Is this 307 a "Y" or a "9"
Old May 10, 2011 | 01:58 PM
Redog's Avatar
Like the title states. I may have a 9 motor in an 85 Delta here. Not that it's a bad thing, but how do you find out?
I know the block ID is going to be the same, so I'm going to try looking at the VIN plate on the side of the block. What would I be looking for on there?
Old May 10, 2011 | 03:32 PM
BlackGold's Avatar
Should be simple, if the engine is an original '85 and has not been modified. In 1985 the 9-code engines still had 5a heads while the Y-code engines moved on to the 7a heads. there are other differences, but that's the easiest to see.
Old May 10, 2011 | 07:38 PM
If it's the original motor, this is easy. It's not a "9".
If it's not the original engine, the VIN derivative won't tell you anything as it does not contain the engine code.
Old May 10, 2011 | 08:00 PM
Redog's Avatar
It's not the orginal motor, I was told it was replaced. The AIR tubes are NOT rusty and crappy looking which I was surpirsed to see.
The battery ground is right above the head ID. I can see the "A" but not the number
carbonf00tprint
Nov 4, 2012 07:53 AM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
leo lymen
Dec 13, 2002 06:48 PM
