307 heads on 350? bump compression up?
Old Feb 15, 2008 | 06:01 PM
HAFROD's Avatar
I don't even know if it would work! I have put 305 chevy heads on a chevy 350 before and it bumped the compression up. Will this do the same on 307 heads on 350?
Old Feb 16, 2008 | 06:57 AM
As far as I know 307 heads are about the worst SBO heads available. I believe the #6 heads are desireable for the SBO.
Old Feb 16, 2008 | 07:37 AM
Most SBC "tricks" do not apply to Olds motors. You need to understand the characteristics of the particular heads - chamber volume, port size, and valve size. In many cases. Olds used piston dish rather than chamber size to vary compression, and head swapping may not even help. Primarily it's the 60's vintage SBO heads that have the 60-64 cc chambers.
greenslade
Mar 29, 2011 03:56 PM
#1CutlassSupreme
Dec 19, 2008 02:31 PM
cutlassinvt
Jul 6, 2008 02:20 PM
bigbrother
Jul 3, 2007 01:12 AM
