307 feels like its about to cut off when driving
Old Jul 30, 2015 | 09:35 AM
QS442's Avatar
My H/O has been driving great since I started driving early summer. I only been driving around town limits but I finally did some highway driving and when I got to around 60mph felt like car wouldn't accelerate and engine was abou to cut off. Once I slowed down car was driving fine, sped back up around 55 mph and felt same thing. Had to slow down and tried to give car gas but car wouldn't accelerate. Car never cut off but felt like it was. I dont have this problem driving around town.
Old Jul 30, 2015 | 10:09 AM
Unfortunately, this could be caused by a large number of possible items. Weak fuel pump, clogged filter sock in the tank, bad ignition coil or other ignition related parts, incorrect float setting or heavy float deteriorated by ethanol, improperly adjusted secondary air valve spring or sticking air valve, etc, etc.
Old Jul 30, 2015 | 10:45 AM
Professur's Avatar
I had this exact problem. Have you run the gas tank down to near empty recently? Change out your fuel filter first. Cheap, easy and my personal candidate for failure. Cut it open and see the sand inside.
Old Jul 30, 2015 | 05:19 PM
QS442's Avatar
I did run the tank down to near empty. I will change out fuel filter. Sounds like a good start.
Old Jul 31, 2015 | 06:04 AM
Professur's Avatar
Try and get a replacement gasket at the same time. The last few filters I've bought didn't come with them, and the store wasn't able to order new ones.
yamahondarider
23
Apr 20, 2018 06:31 AM
Vyse
Mar 17, 2014 08:16 PM
randomarrival
Dec 18, 2012 04:12 PM
BosMobile
Jul 15, 2011 06:35 PM
