30 minute engine detail
Old Jun 24, 2015 | 09:14 PM
cjsdad's Avatar
I have re-sealed the top end of my 330 in my '67 Cutlass. I also installed a 4-barrel factory intake and a Q-Jet carburetor. Everything seems to be working well and no leaks so far. I haven't driven it much though so that may change. While I was rebuilding the carb, I sprayed the engine with a generic engine cleaner and sprayed it off with a pressure washer before installing the Q-Jet. It looks decent, nice and clean, but not very exciting.
So I took a few minutes and spray bombed the engine. The gold paint is Krylon Gold Metalic from HD and the black is Duplicolor Low Gloss Black engine paint. I moved a few things around and used cardboard to "mask" things off. For half an hour, it turned out pretty decent. Not great, but decent.
File Type: gif
File Type: gif
Old Jun 24, 2015 | 09:18 PM
Nice work, I hope the paint was a hi temp type.
Old Jun 24, 2015 | 09:30 PM
cjsdad's Avatar
Not really, I think it said it was good for 250*. I expect some discolorization around the exhaust crossover and around the exhaust ports of the heads. But everything else should be ok for a while. It just looks sooo much better now. There is still a lot of room for improvement.
File Type: gif
File Type: gif
Old Jun 25, 2015 | 12:32 AM
rustyroger's Avatar
'87 Delta 88 Royale
Hats off to you!.
Your ongoing saga of your car is a fine example of how to do a decent job at a budget price.
Perhaps the car isn't gong to win a concours award anytime soon, but you are showing enthusiasts with limited resources that a car needn't be a money pit.
Roger.
Old Jun 25, 2015 | 05:46 AM
cjsdad's Avatar
Originally Posted by rustyroger
Hats off to you!.
Roger.
Thanks Rusty! Not interested in a Concourse Restoration, I'd be afraid to drive it! Concourse is reserved for '32 Packard Phaeytons and such, not drivers.
File Type: gif
File Type: gif
Old Jun 25, 2015 | 07:09 AM
hookem horns's Avatar
If the gold does not last, pick up a can of VHT gold at any parts store. Under $10 if I recall, pretty darn close to original color and holds up well.
Old Jun 25, 2015 | 02:37 PM
cjsdad's Avatar
Thanks Dane. I will probably be pulling the engine when I change out the transmission. If I do, I will probably repaint the whole thing then. Take all the brackets and hoses off and paint everything properly. This was mostly an attempt to stop the intake from rusting, and give it a better look. It was flash-rusting after I used the pressure washer.
JpMotorsports
Mar 31, 2016 07:17 AM
Vader
Nov 7, 2013 09:32 AM
BIGJERR
Oct 29, 2012 02:28 AM
w-30dreamin
Apr 3, 2011 06:30 PM
gearheads78
Jul 6, 2009 01:11 PM
