3” dual exhaust on 330 high compression?
Old May 2, 2020 | 06:52 AM
Drews67Cutlass's Avatar
Any running 3” dual exhaust with the 330?
I have Thornton dual exhaust manifolds. Converting single to dual.
Would I be loosing too much back pressure with 3”?
Old May 2, 2020 | 07:13 AM
There is no such thing as too little back pressure. That's another urban myth that will never die. The reality is that 3" pipes for that size motor are a waste unless you plan to spin it to 7 grand or so. Using 3" pipes with cast manifolds is a joke. Save yourself a lot of fitment headaches and just go with 2.5".
Old May 2, 2020 | 08:00 AM
cutlassefi's Avatar
I’m not even sure I go with 2 1/2 for a 330, more like 2 1/4.
The first time I went from manifolds to headers and dual exhaust on my car, which is a mildly modified 350, I went with 2 1/4 pipes all the way back. I later changed the mufflers etc. and went with 2 1/2 all the way back. I didn’t notice any real difference. And I was running EFI, my fuel map didn’t change much either.
Old May 2, 2020 | 08:39 AM
Appreciate the advice. Thanks
Old May 2, 2020 | 09:02 AM
Agreed, but pre-bent 2.5" systems for A-bodies are probably easier to find.
Old Jan 18, 2022 | 03:14 PM
Tri-Carb's Avatar
https://www.thepartsplaceinc.com/par...haust-systems2
Old Jan 18, 2022 | 04:01 PM
Sugar Bear's Avatar
IIRC factory 455's in performance opted cars with dual exhaust used 2 1/4" so that would be more than adequate for any 330 CID.
Old Jan 18, 2022 | 04:06 PM
This thread is from six months ago. I think the OP already got his answer.
Old Jan 18, 2022 | 04:14 PM
Old Jan 18, 2022 | 04:15 PM
Sugar Bear's Avatar
May of 2020 to January of 2022 = 20 months.
Old Jan 18, 2022 | 04:16 PM
May of 2020 to January of 2022 = 16 months.
Doh! I guess I had put that last year out of my mind...
Old Jan 18, 2022 | 04:17 PM
Sugar Bear's Avatar
That's ok I had to edit my math!!!
Old Jan 18, 2022 | 04:18 PM
Yeah, the Quotes don't lie.
cowboyhedlund
Nov 2, 2018 07:13 AM
67Rocket
Jun 12, 2017 08:53 AM
seanm12
Feb 22, 2015 01:49 AM
REDJET
Nov 13, 2012 02:22 PM
jdiggitydogg
Jan 22, 2012 03:10 PM
