215 heads removal sequence
Old Mar 25, 2017 | 10:27 AM
RocketRonnie's Avatar
Hello, i will be working on removing my engine today at my Grandpas house... I might need to take off the heads to get the engine to fit in my car for transport .. yeah my car..
Can anyone tell me the sequence in removing the bolts from the cylinder head. They are aloy so I don't want to damage them. Thanks for your time.
Old Mar 25, 2017 | 12:13 PM
It really doesn't matter. I've certainly never worried about it. The reason for a pre-determined torquing sequence is mainly to ensure good head gasket seal. That isn't an issue when taking it apart.
Old Mar 27, 2017 | 08:39 AM
I want to thank you Joe for your quick and direct reply, I did read it but was so busy that day. The day kinda sucked, my friend who has a cherry picker broke. This is 65miles from my home. Another guy told me to break the engine loose and with 30$ he would go over to lift it out. Found out my aunt had cancer that day too. I did remove all bolts connecting the 215 to the exhaust, mounts, bellhousing. This is my 1st engine I break down like this so I expected the engine and tranny to just come apart after I unbolted them from each other but that was not the case, any tips on how to break them apart with no damage. Thanks Joe.
Old Mar 27, 2017 | 08:40 AM
I want to thank you Joe for your quick and direct reply, I did read it but was so busy that day. The day kinda sucked, my friend who has a cherry picker broke. This is 65miles from my home. Another guy told me to break the engine loose and with 30$ he would go over to lift it out, but he flaked it on me, apparently some mens word is worthless. Found out my aunt had cancer that day too. I did remove all bolts connecting the 215 to the exhaust, mounts, bellhousing. This is my 1st engine I break down like this so I expected the engine and tranny to just come apart after I unbolted them from each other but that was not the case, any tips on how to break them apart with no damage. Thanks Joe.
Old Mar 27, 2017 | 08:49 AM
Since U Like Pics
Old Mar 27, 2017 | 08:50 AM
Are the engine and trans still in the car? If so, you will need to pull them together and separate them out of the car. The Olds Rotohydramatic5 doesn't use a conventional torque converter - the fluid coupling is inside the trans. There is an input shaft that looks like the one on a manual trans that fits into a flywheel hub that looks like the center of a clutch disk. The configuration of the oil pan sump and crossmember won't allow you to pull the engine far enough forward to disengage that input shaft from the splines in the hub.
Once the engine and trans are out of the car, you'll likely just need to work them apart. The dowel pins often stick in the bellhousing alignment holes. Do be sure you have all the bolts out!
Old Mar 27, 2017 | 08:53 AM
The trans is still connected, I will do as you say. Thanks agian.
Old Mar 27, 2017 | 08:55 AM
The more I work on my olds the more I'm falling in love with them
mmurphy77
Dec 2, 2024 09:19 PM
skryla
Nov 17, 2011 12:12 PM
Franks425442
Mar 9, 2011 12:08 PM
nukesec1
Oct 6, 2009 12:42 PM
stevengerard
Sep 22, 2009 09:07 PM
