1975 350 timing set
Old Jul 23, 2017 | 12:48 AM
midnightleadfoot's Avatar
ph_ckstick1
Question 1975 350 timing set
Hello..
I'm assuming These have the nylon tooth gears timing sets from the factory..
About what mileage are they normally good for.?
Mine is not sloppy but it only takes on tooth to go awol..
Old Jul 23, 2017 | 03:37 AM
It used to be 60-100k miles. If you still have an original set, I would change it out.
Old Jul 23, 2017 | 04:22 AM
ph_ckstick1
No idea if they are original or not.. 90k on clock tho, but timing is tight..
Old Jul 23, 2017 | 06:23 AM
If you pull the fuel pump you should be able to see the gear and chain through the opening.
Old Jul 23, 2017 | 07:23 AM
ph_ckstick1
Thank you..
With the camera probe I should be able to..
My fear is if I go to do a chain I'll say welp I'm in there a cam and lifters,,
and it's all down hill from there..
Old Jul 23, 2017 | 08:15 AM
Hey sometimes valve cover gaskets start that snowball effect...
Old Jul 23, 2017 | 08:25 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have found the mid 70's nylon timing sets seem to not fall apart like the earlier ones. The motors I pulled them out of were well taken care of and great shape inside. I am betting the nlyon was probably more heat resistant compared to earlier model's, not even a crack in the nylon. Both were 76 350's, so still 40 years old. Still a good idea to change it. A far as cam and lifters, either go with a cam like the smog 455 or vin 9 307 cam, a Lunati high efficiency series cam, or leave it alone. The stock cam sucks, only good for low emissions and maybe fuel economy.
Old Jul 23, 2017 | 08:37 AM
And as always someone steps up to help spend your money...
Old Jul 23, 2017 | 08:48 AM
ph_ckstick1
Yes, my c-10 is under that snowball, Somehow a carb gasket on the 350 became a 489bbc swap /build.. I blame elves
Old Jul 23, 2017 | 08:50 AM
ph_ckstick1
All good, part of the hobby.. At least he kept it low key..
not a 455 swap with a 5spd stick.. bla bla bla..
Old Jul 24, 2017 | 10:41 AM
damaged442's Avatar
Yes, they are nylon gears. I got about 92K out of my original timing gear on my 77, before it skipped a tooth...
Old Jul 24, 2017 | 11:19 AM
That may have just been luck. I've thrown the chain on a 1980s 307 with about 120K on it (in my defense, I ASSUMED the mileage was actually 220K, and thus that the chain had already been replaced...). On the other hand, I opened up a 1971 350 with 115K on it to replace the chain, and the plastic teeth looked nearly brand new. Go figure (or else, someone replaced a worn timing set with a new plastic one - but who does that?).
Old Jul 24, 2017 | 11:32 AM
m371961's Avatar
Chrysler LA engines had those also with the same amount of success.
Old Jul 24, 2017 | 09:03 PM
You are right Joe, it could have been luck. Let's face it, nylon gear teeth in a V8 was not a great idea for longevity. If in doubt, replace it.
Leadfoot
Apr 23, 2017 05:39 PM
jpc647
Jun 10, 2013 11:48 AM
tmatador
Sep 29, 2011 12:25 AM
65cutty
Jul 30, 2009 04:04 PM
442scotty
May 13, 2009 05:42 PM
