1974 delta 88 350 ROCKET
This was discussed recently here.
(Sorry - using mobile app with fewer link posting options)
edit: Try the link without the "m."
https://classicoldsmobile.com/forums...ad.php?t=36051
As long as the drive gear and shaft are the same you should be able to change it no problem. I' m going to change mine over to gmhei and am not anticipating any serious problems. Attach the coil wires as directed and good to go. Also find out what your new plug gap is.
i thining about the kit from summit anybody used it before?
1978 Oldsmobile Omega
June 15th, 2014 07:23 PM
Hurst/Olds 73/74
May 30th, 2014 12:56 PM
