1972 Olds 350 Holley Street Dominator Intake - Brackets
Old Jan 17, 2021 | 07:09 AM
JkWheels's Avatar
JKW
I am trying to adjust brackets with street dominator intake on olds 350. Ac and alternator brackets are about 1/4-1/2 inch off. I think because manifold is higher then original.
any option other the reaming open holes to adjust?
Old Jan 17, 2021 | 07:11 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
What car is this in? Pics would be helpful.
Old Jan 17, 2021 | 07:41 AM
JkWheels's Avatar
JKW
Olds 350 Bracket Pictures
It’s olds 350 1972. Here are pictures of ac bracket and how far it’s off
Old Jan 17, 2021 | 08:03 AM
This is a common problem. The boss on the intake is too tall, because that intake has taller runners. Your options are to delete the A/C, machine the cast bracket, or go to an aftermarket bracket and compressor. I've got a similar cast bracket that someone machined for clearance, and obviously now it's incorrect for the stock intake.
Old Jan 17, 2021 | 09:47 AM
JkWheels's Avatar
JKW
almost fits
I’m close everything bolts up and the bolt on manifold is off 3/4 of the hole diameter. I may leave it without bolt to manifold. It is bolted downright with three bolts to block in front and to head stud. How much support can one short bolt to aluminum block provide?
Old Jan 17, 2021 | 09:50 AM
A lot. That bolt reacts side-to-side vibration. Without it, expect to crack the bracket where it bolts to the stud on the head.
Old Jan 17, 2021 | 12:36 PM
JkWheels's Avatar
JKW
Done
Reamed it out and bolted it down with washer.
hope it works.
Charlie_brown
Jan 9, 2021 02:56 PM
ajr2820
Mar 16, 2019 11:31 AM
toolman
Oct 23, 2017 04:45 PM
t_huth21
Feb 27, 2015 12:58 PM
Itza55
Jan 26, 2014 04:13 PM
