67 330 water pump
Old Jan 16, 2021 | 01:14 PM
brianbeez67's Avatar
67 330 water pump
OK my 67 C/S 330 has air conditioning, looking to replace the water pump. Service manual shows pics of ones with and without A/C. The only visible diff seems to be
a circular identification boss (~top left side). Looked at local supply shops, some say with and some say without A/C. Question does anyone know if there is any mechanical
diff between the two?
Old Jan 16, 2021 | 05:42 PM
2blu442's Avatar
I think the key issue is the pump length. Its likely either the 5.1" or 5.6" but I'm not positive. Check out this old thread that discusses pump lengths.
Water Pump Lengths - ClassicOldsmobile.com
Old Jan 16, 2021 | 07:38 PM
All 1967 water pumps are 5.1". Expect every catalog you check to get this wrong.
Old Jan 16, 2021 | 07:44 PM
I'll add that the correct water pump part number for a 1967 with A/C is 388183. That pump used casting number 384786.
Airtex AW773 is shown as an interchange for both that pump and the non-A/C version (388182). This is what I used on my 67.
Old Jan 16, 2021 | 08:46 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Trust Joe for the length needed. There is a mechanical difference. The factory A/C pump has a closed impeller. The non A/C and most aftermarket replacements now have the open impellers. It is hard to say how much more water they move, it may be to prevent cavitation as much as more water movement. A/C and heavy duty cars have more overdriven water pumps compared to regular cooling, non A/C cars.
Old Jan 17, 2021 | 07:45 AM
A bit of info on that:
I was worried about the cooling differences years ago, and after being unable to locate a closed impeller pump or a shop to rebuild an original, I installed a parts store reman with the open stamped impeller. I did not like doing it, but after many years of driving I have not experienced any cooling issues with the open impeller during 110º summer temps and running the AC. This leads me to the conclusion that the open stamped impeller is sufficient to do the intended job.
Old Jan 17, 2021 | 08:34 AM
Joe- is the AW773 water pump open or closed impeller?
I have the 384786 (A/C pp just verified) But, bought a 3 core radiator from OPGI years ago (still in box) found out that after a phone call Between (OPGI and the Manufacture) that the Rad is "NOT"
for an A/C car. I'm not hooking up the A/C (but keeping all the crank and water pump pulleys the same). Trying to figure out what my options are?
Open or closed impeller with current radiator?
Old Jan 17, 2021 | 08:55 AM
Like all new pumps, it has the stamped sheet metal impeller. A three row radiator with a 330 will be fine.
Old Jan 17, 2021 | 09:05 AM
Thanks Joe, will go with the Open/stamped impeller water pump then. Was wondering on a way older thread you had, you had some pictures that gave very specific part numbers (say crank and water pump pulleys).
Where were those pictures from (factory papers?)
Old Jan 17, 2021 | 09:07 AM
If you're talking about this diagram, this is from the Factory Parts and Illustrations Book.
Old Jan 17, 2021 | 09:18 AM
Yes Sir, Spot on, is that book available?
Old Jan 17, 2021 | 09:19 AM
http://www.t.gmpartswiki.com/getpage?pageid=90628
Old Jan 17, 2021 | 09:35 AM
Thanks, will check it out
Old Jan 17, 2021 | 05:22 PM
You are the designated cooling system tester, living in the desert. Yeah, I have not noticed any difference between the open and closed impeller designs as far as cooling. If you don't like having money there is this closed impeller pump. https://flowkoolerwaterpumps.com/pro...df1858c6&_ss=r At least Flowkooler now makes a billet impeller for their pumps, they use to rivet a plate to the open impeller. If anything, I think the riveted plate made the cooling worse on my 403.
REO442
Apr 15, 2020 01:47 PM
brianbeez67
Feb 26, 2020 08:32 AM
therobski
Jul 6, 2018 04:54 PM
therobski
May 20, 2018 06:16 AM
diesel olds
Nov 6, 2013 03:39 PM
