1972 Cutlass 350 Elelbrook 3711 intake
Old Aug 31, 2021 | 04:20 PM
autcool's Avatar
Hello all Just looking for some info I have a stock 350 with a 3711 intake , an I am wanting to go with a Edelbrock carb
Carburetor, Edelbrock, 600 CFM, Performer, Electric Choke How good are these carbs Thanks for any info
Old Aug 31, 2021 | 04:28 PM
66SportCoupe's Avatar
Run a Qjet or a Holley carb. Edelbrock carbs go in the trash here.
Old Aug 31, 2021 | 04:36 PM
autcool's Avatar
I have a Q-jet on there now I had it rebuilt about year an a half ago an just can't get it to smooth out it surges at an idol But when its in gear surge go's away Thanks I will look into a Holly
Old Aug 31, 2021 | 04:54 PM
Keep the Qjet. Get it rebuilt right. You'll be better off. Seriously
Old Aug 31, 2021 | 05:05 PM
autcool's Avatar
I will look into a different guy to rebuild it. I was l lucky to have it out 10 times, in the last time I had it rebuilt only put 400 miles ago on it ran good for about 200 miles Thanks for the info
Old Aug 31, 2021 | 05:07 PM
There are a few recommended guys on here. Just don't have that info handy
Old Aug 31, 2021 | 07:15 PM
gs72's Avatar
72Cutlass S
E-Brock carbs are fine and a lot easier to dial in than a Q-Jet. I would go with a 750 cfm since thats what most all Q-Jets are. If you are comfortable working on the carb yourself get a Edelbrock tuning kit for it and follow the instructions for the manual choke version of your carb even if it is a electric choke. Even if you have a mechanic tune it you will have a better outcome over a Q-Jet. Most mechanics can’t tune a Q-jet.
Old Sep 1, 2021 | 04:50 AM
cutlassefi's Avatar
Ditch the 3711 and get a 7111 instead. The ports on the 7111 are still plenty small
enough to get good throttle response when using the right carb.
Next I’d recommend the 750 Brawler. Very easy to tune seeing as how it has changeable air bleeds, jets, power valves etc.
And as is typical, no one has yet to mention getting a wideband to do the job right. Don’t trust ANY carb builder short of Dale Cubic. They’re all just making an educated guess at best. Get a wideband.
Old Sep 1, 2021 | 05:01 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
There have been many disappointed people on this site who have bought Edelbrock carbs that tried everything to fix there ailments. The new AVS2 carbs would be the only one to even slightly consider. As Mark said, even a Qjet expert like Cliff Ruggles is making an educated guess, if you go the Qjet route. Get a wideband to tune your carb. It sounds like you need an idle circuit recalibration or you have a vacuum leak. Were the the throttle shaft bushings done on your carb? Is your motor bone stock?
Old Sep 1, 2021 | 02:29 PM
autcool's Avatar
Thanks for the info after doing some research I hook the vac advance to manifold vac an it smoothed out They took out the points Distributor an put in eletronic Distributor so I will explore this route now
Old Sep 1, 2021 | 03:37 PM
What is the timing set at?
Old Sep 1, 2021 | 03:40 PM
autcool's Avatar
Its 2 notches below TDC I can't get down there to see the #'s
Old Sep 1, 2021 | 03:59 PM
autcool's Avatar
got my light on it set at 0
Old Sep 1, 2021 | 06:39 PM
The previous owner may have set the timing like the original points distributor calls. I have seen multiple curves but most HEI need around 20 degrees base to hit the 34 to 38 degrees needed. Basically the vacuum advance bumped the timing down low that it needed.
mefirst72
Aug 20, 2021 11:30 PM
asscutl
Dec 6, 2018 05:44 AM
tgilligan
Mar 5, 2018 06:30 PM
OldsManNJ
May 23, 2012 08:20 AM
Chumley
May 24, 2007 09:39 AM
