1971 Cutlass Fuel Line
Hi guys,
So I am going to be changing the carburetor among other things this weekend. I just went out to make sure I have everything I am going to need to do it this weekend and noticed something that lead me to some questions. The flarenut holding the fuel line in - whoever had it apart last messed it up really nice and I can see where they used vise-grips to get it back in. It is in rough shape. Best I can tell it is a 9/16" wrench, does that sound right?
What is in there, just an o-ring? If so, what size? I would like to pick up a new one to put in there. Is some of that thread tape a good idea? Other than that it looks straight forward, I just want to make sure I have everything I need to deal with the flarenut and whatever is behind it. Hopefully they didn't go too crazy with the vise-grips tightening that up or I may never get it out.
Thanks!
Thanks!
Hi guys,
Thanks!
Thanks!
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/480x332/80_inverted_flare_diagram_large_a84485ce44be387cb06904f4793ff2fff59b60f4_010af254f9e309e42034e63cc8960b634ba0e161.png)
When you try to reconnect the fuel line, one trick is to start the flare nut threads in the carb BEFORE bolting the carb down.
Using an improper wrench on the lines causes all the trouble. Invest in a set of "flare nut" wrenches designed for this particular job. You'll thank yourself every time you use them. Always use a back up wrench on the filter fitting to prevent damage to the carb threads.
68442Convertible
June 19th, 2018 08:47 PM
