1971 350ci Timing Gear & Oil Pan
Old May 8, 2015 | 10:50 AM
jeff70's Avatar
I have my 350 out for a timing gear change and detail of the engine compartment and motor.
A few pics
Questions.....
This is the first time I've torn into a Olds motor, I believe its on TDC the #1 piston (drivers side front) is on the up stroke & the rotor is pointing to it. But the timing mark on the cam gear is in the 12'Oclock position is this right?
Any tricks to sealing up the new oil pan front/rear main seals, timing chain cover & water pump gaskets for a leak free fire-up?
I have thread sealer & Med (blue) Loctite should these be used in the reassembly?
Thanks Guys!
Old May 9, 2015 | 05:59 AM
Destructor's Avatar
How many miles on it, I have to do my timing chain someday as a precautionary measure. I'm at 82,0000.
Old May 9, 2015 | 07:12 AM
captjim's Avatar
Originally Posted by jeff70
Questions.....
Yes, this is correct. You can also install it with the dots lined up at 6 and 12 o'clock, which is TDC on the exhaust stroke, then install the distributor later. I recommend this method, it is pretty easy to damage the dist if it is installed when dropping in the engine. Also, aftermarket chains can be off, if you can, it would be good to degree the cam.
As to the pan, use the brush on aviation type sealant on the long sections and RTV Black on the 4 corners where the end seals hit the cork. Take your time tightening the pan down and do not over torque.
Old May 9, 2015 | 08:33 AM
jeff70's Avatar
It has 144k.
CaptJim I never pulled the distributor the motor came out with it in.
Should I run Loc-tite?
Old May 9, 2015 | 09:09 AM
captjim's Avatar
It has 144k.
OK, you just have to be careful dropping the engine back in. Yes, Loc-Tite on both the crank and cam bolt and torque to spec.
Old May 9, 2015 | 11:34 AM
Octania's Avatar
Other fasteners, no loctite
no sealer needed on water pump bolts though the lower center 1/4" bolts can be sealed with say form-a-gasket #2.
If you have the engine OUT, as it appears, it would be a good idea to replace the freeze plugs before they rust thru. Super easy right now. Form-a-gasket #2 is good for those also.
Old May 9, 2015 | 12:11 PM
Nice timing on the timing set, looks like it was just getting ready to drop all its plastic bits. Nice work on the painting also.
Old May 9, 2015 | 01:44 PM
captjim's Avatar
Good idea, just be careful installing them. Clean the block VERY well with Emory cloth or similar. Put some sealant on the plug and allow it to get tacky, then use the proper tool to press them in. Also, when doing the rear, one plug is the oil galley plug, not a freeze plug.
Old May 10, 2015 | 01:34 AM
SkylinesSuck's Avatar
Uh oh. I recently did my timing set and never used loctite on the cam bolt. How worried should I be?
Old May 10, 2015 | 05:55 AM
Destructor's Avatar
How many miles were on that timing set?
Old May 11, 2015 | 12:10 PM
I wouldn't worry about it as long as you torqued it properly. I have never used loctite on that bolt; just torqued it to spec. 4 camshaft changes in the past 33 years with no issues.
Old May 11, 2015 | 10:59 PM
Awesome, thanks!
defiant1
Aug 12, 2014 04:43 PM
shaks 442 clone
Mar 11, 2012 08:27 AM
sixty9olds
Aug 26, 2009 11:49 AM
442scotty
May 13, 2009 05:42 PM
Wasted
May 11, 2008 01:41 AM
