1970 oldsmobile cutlass with 1977 350 rocket
Old Aug 2, 2019 | 06:17 PM
Mlunsford33's Avatar
Please help 1970 oldsmobile cutlass with 1977 350 rocket
Could some one please tell me in detail how too advance the timing on this motor please it is all orginal motor I have a 600 edelbrock 4b on it with a edelbrock breather I have ordered long tube headers also whyle in neutral it runs fine can rev it up slowly but if you try too lay on the fuel it will try and die out also whyle driving it does the same thing any pics and info would be greatly appreciated
Old Aug 2, 2019 | 06:18 PM
Old Aug 2, 2019 | 07:37 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
First off it could be the Edelbrock carb, many have issues with them. The timing advance is done by loosening a hold down to right of the base. Advancing, push the vacuum advance towards the firewall. You want 20 degrees at idle with the vacuum advance unhooked with the hose plugged.
Old Aug 2, 2019 | 07:54 PM
So loosen the hold down on right side of distributor take the hose off and plug it and turn clockwise ? Thanks for the response
Old Aug 3, 2019 | 09:03 AM
Yes. The rotation of the rotor is counterclockwise but turning the vacuum advance clockwise advances timing.
Old Aug 3, 2019 | 10:37 AM
Okay thank so when I lossen it and turn the distributor how far do I turn it
Old Aug 3, 2019 | 11:19 AM
A timing light is best to see exactly where it is. Basically go until it cranks over hard then turn it back a bit.
Old Aug 8, 2019 | 06:33 AM
So got my headers was attempting too I stall them broke too manifold bolts on passenger side and I cant get a drill in there I've tried vise grips can anyone help
Old Aug 8, 2019 | 06:34 AM
Old Aug 11, 2019 | 03:02 AM
brownbomber77's Avatar
Oh jesus......unfortunately, if you super heat it with acetylene and it doesn't come out, it will most definitely need to come off the engine and get drilled out. Man, that sucks. BUT if you do need to pull the head off, may as well pull the other off and replace with a set of earlier heads. Sorry to be the bearer of bad news....
Old Aug 11, 2019 | 06:40 AM
The top center one can be left as is. Many leave that bolt out with headers. An angle drill should reach the other one if heat or welding on a nut won't work.
Old Aug 11, 2019 | 06:42 AM
What headers are you using? You should have bought the cheap Stainless long tubes. They hang low with your 350 but you are going 455 so they would work great with them.
OLDSter Ralph's Avatar
You might be able to drill out the broken bolts from below if you have it up on a hoist. Of course, you'll need a right angle drill and short drill bit. Make sure you are centered and straight with the hole. You might be able to have a good "muffler shop" remove the broken bolts. I think your best bet is to have a GOOD muffler shop drill out the broken bolts and put the headers in.
Old Aug 12, 2019 | 03:10 PM
VinMichael's Avatar
Screw a 3/8 nut on the threads with red Loctite. Or weld the nut on. Then try putting a wrench on the nut taking it off.
Old Aug 12, 2019 | 03:18 PM
Do both broken bolts have that much thread sticking out? First soak in a goo penetrant. You can heat the area around the bolts with a torch and then screw them right out with vice grips.
Old Aug 12, 2019 | 04:10 PM
Thanks alot guys I got it out with a drill bit and I'm using flowtech headers
Old Aug 13, 2019 | 11:03 PM
Dayum. Good for you. Super lucky. Hope the install goes well. Might wanna take a look at those bushings ya got, too.....ha
83calais
Oct 18, 2016 11:58 AM
s i 442
Apr 5, 2015 07:11 AM
jkoester122
Aug 30, 2011 05:04 PM
al714
Apr 11, 2011 08:15 PM
defiant1
Jun 26, 2010 08:37 AM
