1970 Cutlass Supreme 350 Coolant Overflow Tank
Hi All,
Wanted to get some opinions on whether a coolant recovery/overflow tank is recommended and if so, what everyone's setup looks like. I've seen the reproduction bottles (quite pricey) but comes with the correct radiator cap, bottle and bracket. My current radiator (aftermarket) has a top port about an inch or so below the cap which is currently not being used and has a rubber cap/clamp combo. Is this port used for the recovery/overflow tank if I end up getting one?
No, the coolant tank is hooked up to your overflow port just below the cap. There are many repro and aftermarket coolant recovery/overflow tanks from inexpensive to very expensive. If your going to do it, I'd do the cap and tank similar to how the late model cars work.
I will say that yes, an overflow tank is recommended.
If you have a radiator with a heater hose port below the cap, going with an expensive authentic style repro overflow tank is a waste in my opinion, as it's obvious the radiator is a Chevy style and not "correct" for the vehicle. Just get an aftermarket tank from the local auto parts store for under $20 or a GM one from a salvage yard and a closed system radiator cap to go with it.
https://www.oreillyauto.com/shop/coo...niversal-17482
The heater hose return was moved to radiator cold side tank to correct a heater core gurgle/moan on early 70s cars that some owners found objectionable. The "factory fix" from 1973 Tech Bulletins would horrify some of you and made a big stink at Nationals judging in late 90s because the judging team didn't know anything about it and docked the car hard. Basically a large brass tee that went in the lower radiator hose, and the heater return hose attached to that. Looked funky, but it worked and shut the complaints up.
That episode convinced me that OCA judging is not what it should be and needs to incorporate training on Tech Bulletins and Service Guilds.
If your cooling system is in good shape, filled to CORRECT level (2" or so below the radiator fill neck) and the pressure cap is holding pressure and not puking, I see no reason to install a coolant recovery tank unless racing sanctions or pinheaded local regulations require it.
Hi All,
Just wanted to help by posting this. I have an aftermarket radiator also. This is the tank supplied by Fusick Automotive. Much better price then OPGI. The one note, if you have the nipple under the radiator cap with the rubber nipple over it ( picture 4 ). Check that cap on a yearly basis for drying out and cracking. They dry out quickly.
For the price of most of the reproduction tanks, I may just keep it filled about 2 inches below the neck and keep an eye on it. Shelling out that much for the recovery tank isn't in my budget at this point.
