1967 Cutlass 330 4bbl RH Head ID Question
Hello!
I have a 67 Cutlass Holiday Coupe 330 4bbl. I was checking the RH head to ID if it is low or high compression – I'm seeing W442294.
From all my research – the 67 heads should start with a 3 after the prefix letter, correct?
Any ideas? Thanks.
Any ideas? Thanks.
You are wrong. The engine unit number started at 3xxxxx and was incremented over the model year. A 4xxxxx number just means that Olds made more than 100,000 330 motors that year (which they did). And as noted above, the absence of a "G" suffix means that this is an L65 low compression 2bbl motor.
MudEye
June 2nd, 2015 10:45 AM
