Losing log in Info
Losing log in Info
The site seems to be losing my login info even though I am checking the remember me box. I have to fill in the info each time I use the site. Any suggestions as to what the problem may be? Larry
It may be the browser you are using. If it is deleting your internet history, that will happen. I have mine set to delete when I close the browser so I always have to log in. Your login info is saved as a cookie on your computer so it is most likely not the site.
