security token...
The security token is a cookie which is set to expire after some number of minutes (maybe an hour). If you have a window open for longer than that time, then if you try to perform an operation from that window, it won't ler you. If you reload the window, it will work again.
help442onguam
Feb 5, 2012 08:38 PM
