Site Help Ask your questions here about how to use the site.
security token...
Old Mar 24, 2013 | 10:05 AM
sammy's Avatar
Sammy70 455 Supreme
security token...
what does this term refer to? As with others, occasionally will not let me post due to it's absence......
Ted
Old Mar 24, 2013 | 10:54 AM
Lady72nRob71's Avatar
Try logging out, clear your cookies, then re-log in and click the "remember me" box when entering your user name and PW.
Old Mar 24, 2013 | 11:27 AM
The security token is a cookie which is set to expire after some number of minutes (maybe an hour). If you have a window open for longer than that time, then if you try to perform an operation from that window, it won't ler you. If you reload the window, it will work again.
Old Mar 24, 2013 | 04:19 PM
And if your computer in on a 'token ring' LAN, and you unplug the LAN cable, the token can fall out and roll to the darkest corner of your room without notice...
Old Mar 24, 2013 | 08:53 PM
Don't blow it out of proportion, though - it's really just a token issue.
Old Mar 24, 2013 | 09:31 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Next time it happens try holding the control key while hitting the F5 key. this will refresh/load the page.
steverw
Site Help
Oct 5, 2014 12:12 PM
fknrc
May 15, 2014 08:40 PM
help442onguam
Feb 5, 2012 08:38 PM
import extermination
Body work
Aug 11, 2009 06:59 PM
87candycutty
May 27, 2007 10:00 PM
