Site Help Ask your questions here about how to use the site.
Correct way to answer private messages?
Old Oct 15, 2013 | 01:34 PM
62 Cutlass Convert's Avatar
I am not sure I actually responded to the private msg I received.
I added my answer within the same window and hit submit message. Is that correct or?
Old Oct 15, 2013 | 01:35 PM
Yes, you can check by looking at the message sent window also.
Old Oct 15, 2013 | 01:38 PM
Thanks, just checked that now.
Old Oct 16, 2013 | 01:31 PM
Omicron's Avatar
Site Admin & Motorhead
It's best to put your response completely above or below whatever the person who PM'd you wrote - especially if you're quoting them - and stay consistent where you put your responses. That way it's easy to read them.
Old Oct 16, 2013 | 03:53 PM
So I should click in the window of their message above or below it, respond, and "submit reply" back to them with "sent" checked.
Is that right?
Old Oct 16, 2013 | 03:55 PM
I usually enter mine above.
Old Oct 16, 2013 | 04:02 PM
Thanks all for the help. As you can tell I'm new at this.
Old Oct 16, 2013 | 04:18 PM
Your welcome we all went through the learning curve.
Old Oct 18, 2013 | 09:51 AM
Omicron's Avatar
Is that right?
You can either type your response in the "Quick Reply" box below the message you received (in it, you'll see the text of the message(s) you've gotten, starting with a [quote= and ending with a /quote]. You can add your response above or below what they wrote you. Click "Submit message" when you're ready to send it. OR you can also click the "Reply" button (lower right corner of the original message) and it'll take you into a screen with more advanced formatting options, and the ability to change the who the message goes to, cc or bcc other people, etc. Finally you can also use the "Forward" button (right next to the Reply button) to send the message to other people.
brown7373
Aug 23, 2015 01:54 PM
stellar
Site Help
Mar 19, 2012 02:31 PM
RATCHETMASTER
Site Help
Dec 20, 2011 12:15 PM
71"S"
Mar 17, 2010 11:14 AM
