61-70 Big Cars, "Darksiders" unite !
Old December 27th, 2016, 10:01 PM
  #161
Forward into the Past
Human's Avatar
Count me in as a member of this club. I've posted elsewhere about the '64 Dynamic 88 Convertible that's eventually coming my way. I've only been waiting on this car for the better part of 40 years. Dad bought it from the original owner in 1978 when I was 14 years old with the idea of fixing it up for me to drive when I got my license at 16. That never happened and he finally got it painted and put a top on it after I graduated from college. To this day, I've never driven or even ridden in this car, although I do remember sitting in it and doing my homework when one time when the house was being fumigated. A friend of my dad's has the car at his place now and is working on getting it running again after sitting for 30 years. It's a gradual process and there's no real timetable for when the car might find its way to my driveway. What progress is being made seems to be happening in fits and starts. I asked Dad about it over Christmas and got the usual vague 'he's working on it' response, which more likely means he's not working on it right now. I'd love to post some photos of it but I haven't seen the car since 2004. I've been waiting for this car since Jimmy Carter was in the White House, so I guess I can hold out a little longer.
Human is offline
Old December 28th, 2016, 08:15 AM
  #162
btw
Smokin' BBQ Member
btw's Avatar
Originally Posted by Human
Count me in as a member of this club. I've posted elsewhere about the '64 Dynamic 88 Convertible that's eventually coming my way. I've only been waiting on this car for the better part of 40 years. I asked Dad about it over Christmas and got the usual vague 'he's working on it' response, which more likely means he's not working on it right now. I'd love to post some photos of it but I haven't seen the car since 2004. I've been waiting for this car since Jimmy Carter was in the White House, so I guess I can hold out a little longer.
I was at the White House when Jimmy Carter was POTUS so I'm hoping you have this car in your driveway during the Trump years. I suggest getting an address of where the car is being worked on and let's drop in with a few cold Olds beverages....
btw is offline
Old January 2nd, 2017, 05:41 PM
  #163
Nitroracer's Avatar
My winter project for the Wagon was to get a front Disc setup put together before I'm out driving again in the spring. I found a SSBC A129-13 kit in the clearance section at Summit on a whim and bought it hoping I could make it work on my 64', even though it is meant for 65-69 cars. Turns out the bolt pattern for the bracket is the same, but the lower bolt when the steering arm bolts on is smaller, and I only had one bracket.
Since I needed another bracket made I decided to improve upon the setup a bit, by running 12" 99-04 Jeep Grand Cherokee rotors. Bracket V1.0 is almost ready to go on the car but cutting 3/8 steel with an angle grinder is slow going.
Nitroracer is offline
Old January 4th, 2017, 10:12 AM
  #164
Kennybill's Avatar
To Nitroracer, Wow, it's like Deja vu, all over again! I was at Summit Racing in Tallmadge yesterday at noon. I saw a SSBC A129-13 kit in a beat up box. I went through the kit and going by a picture print out of a picture of the kit, I thought it was missing a few things. The master cylinder and the proportioning valve were missing. The picture showed the 2 larger brackets that the caliper bolts to and showed 2 smaller brackets. Having seen the Scarebird setup I wondered if the smaller brackets were necessary. I showed a employee what was missing. After talking to a supervisor and me "whining" about a veteran/senior discount we agreed on a reduced price. I called SSBC today and the technical guy was helpful. Seems Summit had the wrong picture and there is no smaller brackets. He told me the 510 caliper is from a 1969 Camaro. The rotors are machined by them to work. He said they had trouble with some hubs being different sizes. I read about some hubs needing to be machined. He said they were discontinued. It seems strange we both bought these SSBC setups from Summits clearance racks the same day.
Kennybill is offline
Old January 4th, 2017, 05:17 PM
  #165
"me somebody" site member
aliensatemybuick's Avatar
Of possible interest to you early 60s B-body guys:
http://www.ebay.com/itm/1964-63-62-O...xYY01K&vxp=mtr
aliensatemybuick is offline
Old January 7th, 2017, 03:24 PM
  #166
Nitroracer's Avatar
The similarities are crazy on that one. What are you installing the kit on?
Old January 7th, 2017, 03:37 PM
  #167
Nitroracer's Avatar
Made some more progress with a chunk of 3/8" stock and have one rough cut bracket fitting on the car now. I need to punch out the top mounting hole and drill/tap for the caliper bolts. My bracket is bigger than the original SSBC version, and now more resembles the scarebird setup. The spacer is 8mm, and with some longer studs I should be good to go. The biggest surprise is how capable my jigsaw was with a cheap harbor freight metal blade for the inside curved cuts.
Old January 8th, 2017, 06:51 AM
  #168
dennis_30281's Avatar
Metal repair
Here's a from scratch repair I made to the front of the left rear inner wheel well on the 1962 Starfire I'm restoring. I had to do this before I could continue with the lower quarter panel repair. I bought a lower quarter panel patch panel for a 63 Impala, but it is about 3 inches short, so I will attempt a cut, grind, weld fit on the panel. Here are some pics.
dennis_30281 is offline
Old January 8th, 2017, 10:57 AM
  #169
Kennybill's Avatar
The two 1967 98's I have are drum brakes and in good working condition. I have a 1966 Dynamic 88 convertible tucked away in one of my buildings. I'm planning on bringing it out and getting it back on the road. I plan on putting the SSBC disc brake setup on it, seeing as they need all redone anyway. I always like to have everything I need before starting a project.
Old January 10th, 2017, 07:05 AM
  #170
btw
Smokin' BBQ Member
btw's Avatar
..... tucked away in one of my buildings.
I see new construction in my future....
What's happening Darksiders?
btw is offline
Old January 31st, 2017, 08:16 AM
  #171
chevoldjp's Avatar
63 Fiesta project
Post in new members back in spring. Started working on "Rhonda" and just returned from a ten hour one way trip to Wisconsin and brought home a parts car.
Rhonda
Parts donorEngine in parts car is a 394 Sky Rocket looks to have just over 100k on car. Using most of interior, chrome and stainless, drivetrain but will have some pieces to sell. Darksiders you can tell me do the trunk pieces made of fiberboard have any value? The ones on this car are in great shape and I will not need them
chevoldjp is offline
Old January 31st, 2017, 04:25 PM
  #172
394 engine
Are you selling the engine? I think that engine is the low compression engine, if so is it just a matter of head gasket thickness or are the heads different from the Starfire 345 HP 10:5 comp ratio?
Dennis
Old January 31st, 2017, 10:21 PM
  #173
Phantom Phixer
Charlie Jones's Avatar
Dennis
The heads are all the same , Dennis .
The compression ratio was determined by the depth of the piston "dish" , or the lack thereof , in the Starfire's case .
The motors were originally built with steel-shim head gaskets .
They were about half as thick (compressed) as the Fel-Pro gaskets available today . This will drop compression somewhere between an eighth to a quarter point . I would guess .
The low compression engines were painted green . Instead of red .
Charlie Jones is offline
Old February 1st, 2017, 09:25 AM
  #174
394 engine
Thanks Charlie, After your post I looked at the engine in my 62 Starfire hardtop. The engine is as green as a Georgia line and no sign of been repainted. It has a 4 bbl carb and chrome valve covers. The book says Starfire engines are red! What do I have here? The nbr on the left head starts with G394 and the car was built in Atlanta.
Dennis
Old February 1st, 2017, 09:43 PM
  #175
Phantom Phixer
Dennis
If the engine is green and it has a 4 barrel , it is probably an export engine .
Special low compression 4 barrels were installed in cars that were being exported to places like Mexico , etc. where the octane quality of the gas was poor .
Old February 18th, 2017, 05:10 PM
  #176
bkcraun's Avatar
1964 Dynamic 88
bkcraun is offline
Old February 18th, 2017, 05:31 PM
  #177
Human's Avatar
That looks like a nice, solid car. I like the two-tone paint scheme with the slightly lighter color on the roof.
Human is offline
Old February 18th, 2017, 08:09 PM
  #178
Phantom Phixer
Nice car !
Any special plans for it ? Or are you just leaving it as it is ?
Old February 19th, 2017, 12:40 PM
  #179
D. Yaros's Avatar
When you say green, do you mean like this -
1962 Oldsmobile 394 c.i. V8, 2 bbl, low compression (8.75:1) engine
If yes, then it is definitely the low compression engine. A little surprised it has a 4bbl carb, as I am sure most were fitted with the 2 bbl.
D. Yaros is offline
Old February 21st, 2017, 08:51 AM
  #180
Engine color
The valve covers appear to have been painted. The green that they paint Ed the engine s was almost a military olive drab.
Dennis
Old February 27th, 2017, 09:15 AM
  #181
MichiDan's Avatar
I already tossed up a few pictures of my Starfire on the intro forum. Got invited over here, a good thread to browse. Here's a different picture of my 64 as an entry payment into the darkside club.
MichiDan is offline
Old February 27th, 2017, 09:23 AM
  #182
Don R.'s Avatar
Secret confession - I love my 63 but the 64 Starfire is my favorite.
Don R. is offline
Old February 27th, 2017, 11:54 AM
  #183
bkcraun's Avatar
Nice car !
Not going the full resto. Interior is pretty clean and original.
bkcraun is offline
Old February 27th, 2017, 01:34 PM
  #184
btw
Smokin' BBQ Member
btw's Avatar
Nothing like a big '64 Dynamic!
btw is offline
Old February 27th, 2017, 04:44 PM
  #185
Phantom Phixer
Welcome to the "darkside" , VERY nice Starfire !
Old May 14th, 2017, 02:06 PM
  #186
Hillbilllystarfire's Avatar
New to site 1964 starfire
Posted some pictures and details in the newbie forum. But here she is old "Gertrude." Looking to get the wipers going soon, heat, and figure out what to do about s leaky gas tank. Otherwise I'm completely surprised at how this car performs. She does like the gasoline.
Hillbilllystarfire is offline
Old July 7th, 2017, 10:02 PM
  #187
61Bat's Avatar
Just checking back in here to see if I missed anything .
^Love the dark green Starfire above.....The more I look at the "Big" Old's of the mid 60's and what nice examples can be purchased at very decent prices I'm thinking there might be one in my future if the right one comes along.
Just don't tell my wife lol........
61Bat is offline
Old July 7th, 2017, 10:05 PM
  #188
61Bat's Avatar
Oh, and a link to my Starfire interior install in my 61 Dynamic bubbletop...
https://classicoldsmobile.com/forums...y-hardtop.html
61Bat is offline
Old July 7th, 2017, 11:17 PM
  #189
Phantom Phixer
Need parts for 63
I'm going to the OCA nats in Alburquerque .
Here is a link to a list of stuff I need to finish my car .
https://classicoldsmobile.com/forums...buquerque.html
I'm going to be there also: for the "Classicoldsmobile Nationals " in the Coronado room of the Marriot on Friday afternoon too .
Hope to see some of you "Darksiders" there.
Old July 10th, 2017, 06:16 PM
  #190
Nitroracer's Avatar
I finished my front disc setup earlier in the summer and I've been running around all over the place. Took a trip out to Ohio for the Roadkill zie tie drags a couple weeks ago.
Old July 12th, 2017, 06:33 AM
  #191
Russ's Avatar
Starfire exhaust
I'm looking for a dual exhaust system with resonators for a 1965 Starfire convertible. Can anyone recommend a good source to go to?
Russ is offline
Old July 12th, 2017, 07:45 AM
  #192
Oldsmaniac's Avatar
I have had great results with Classic Exhaust. Reasonably priced and fit well. Only thing is they will cut the long pipes for ease of mailing and they make the ends so one pipe slides into the other for clamping. I am not sure if the 65 Sfire had a special resonator for the side exiting exhaust, this you will have to ask about.
Oldsmaniac is offline
Old July 12th, 2017, 08:23 AM
  #193
61Bat's Avatar
I used a Classic Exhaust system and it fit well aside from the mufflers which I ended up using something else.
The problem was the had a 90deg bend going in and out of the muffler and to get the tight fit I wanted they came out at the wrong angle. By the time I was done I probably could have had a local muffler shop install a custom set of duals for me.
So I did use their exhaust and the quality and fit I would say were very good aside from the muff's which I probably could have made work but I didn't like those welded 90deg bends which also meant no custom exhaust tips.
61Bat is offline
Old July 12th, 2017, 09:27 AM
  #194
Don R.'s Avatar
Unless you are doing a show points restoration find a good local muffler shop that does a lot of custom work. I've used Rich's Performance Muffler in Wylie, TX for my last three jobs and have been very pleased. Here is what they did on my 63:
Don R. is offline
Old July 13th, 2017, 08:12 AM
  #195
Russ's Avatar
Thanks for the advice. I'll give Classic Exhaust a try. My car has an exhaust system on it but it's pretty well rusted out. The resonators look like straight pipes on each end. The side exiting exhaust tips are bent to line up with the resonator. The mufflers are also straight pipes in and out. I think Classic should fit with no mods.
Russ is offline
Old July 13th, 2017, 09:01 AM
  #196
61Bat's Avatar
I just remembered.....looks like the Classic Exhaust is exactly like in my factory manual ie. they probably use all factory bend dimensions so whatever the manual shows is 99% probability what you will get so if your car has a replacement system on it now no guarantee that IT is stock so make sure check your manual.
61Bat is offline
Old July 15th, 2017, 08:23 PM
  #197
Phantom Phixer
The Darkside roster
Wow! This thread has almost reached 200 posts .
And it has become a "clearing house" of information for these cars .
That is exactly what I intended to do , when I started it in 2014 .
60 classicoldsmobile,com members have posted that they have a 61 - 70 big car on this thread .
Here is a list of them , in the order that they posted .
1. Charlie Jones
2. Aliensatemybuick
3. D.Yaros
4. Jetstarjim
5. Oldskeeper
6. m37961
7. Oldsmanic
8. DownBoy
9. aussie oldsmobile98
10. Summerof84
11. KQQLCAT
12. spohn.mike
13. jaunty75
14. oldsboy Dino
15. SHub'68
16. Don R.
17. dpresita
18. Jeff K.
19. Sean Miller 063
20. andyolds 88
21. ghsot
22. dynamic 63
23. bigoldscruiser
24. jetstar88mike
25. olwreckman
26. Frankie B.
27. the oni boi
28. Atomic Myke
29. Star General
30. Classic 65
31. bw1339
32. Kennybill
33. B964
34. Higgins
35. BTW
36. fnshow 55
37. 61 Bat
38. DynamicIdiot
39. JandK
40. Nitroracer
41. peteyb
42. mjmaire
43. SleepyBeaver
44. Ultima 13
45. dennis 30281
46. Human
47. Chevoldjp
48. bkcraun
49. MichiDan
50. Hillbillystarfire
51. Russ
52. payan 64
53. oldsjoe
54. OLDSter Ralph
55. OLDS98VERT
56. Weezer
57. 66delta
58. Vistabrat72
59. Herbie
60. golden rocket
By the way , Joe P. , I know you have a 68 Delta .
If you post on this thread , you can be #61 .
Last edited by Charlie Jones; February 9th, 2018 at 09:35 AM. Reason: update 2/7/2018
Old July 17th, 2017, 05:31 PM
  #198
Thanks Charlie
Thank You Charlie for starting this thread. Most of the topics in the general forum seemed to have moved out of the sixties and the big cars into the seventies and the Cutlass and 442s etc. I will ask a question here even before going to one of the advisors in the OCA. Thanks again...
Dennis...1962 Starfire convertible
Old August 12th, 2017, 07:44 PM
  #199
golden rocket
golden rocket's Avatar
Guess I'll throw my hat into the ring. 1967 Delmont 88 425 Hardtop Coupe. Picked it up this past February. Showed 69,305 miles when transport company brought it to me. I bought it from the 2nd owner who picked it up at an estate sale, but he hadn't changed the title over, was still open. 425 "P" code 2 barrel engine (9.5:1 C.R.?) turbo 400 automatic, power steering and brakes, pushbutton AM radio and manual antenna, manual air conditioning. Still had the Packard plug wires on it, and points pitted out pretty bad. Lot of stress cracks in lower body of carb, etc...etc...
Interior is original, and other than a hole in the headliner, and 2 splits in the dash pad is very clean. I posted pictures of it last night in good mawnin' thread. Will post again here.
1st car my wife and I bought on time back in 1970 when we got out of the Army was a 1966 Dynamic 88 2 door hardtop. Yes, it was a 425 2 barrel, automatic. The most trouble free car we ever owned. Been looking ever since. This is our 46th anniversary present to us, after 4 kids, countless foster kids and 15 grandkids, we owe it to us.
golden rocket is offline
Old August 12th, 2017, 08:07 PM
  #200
jaunty75's Avatar
The black air cleaner, if correct, would indicate the low-compression version. The compression ratio is 9.0 to 1.
From the 1967 Olds brochure. Yours would be the second engine from the left, top row.
From the 1967 Olds Dealer Specs book. The 300 hp version of the 425 was the low-compression version. Used regular fuel. Standard in your car, with an automatic transmission, would have been the high-compression, 310 hp version, but the low-compression version was a no-cost option.
jaunty75 is offline
Quick Reply: 61-70 Big Cars, "Darksiders" unite !
