58 98 frame swap help
Hey you guys ! Was wondering if you guys can give me some info. I Have a 58 98 2 door hardtop. It's been a mild kustom the past 30 plus years . I've owned it the past 2. It was in a bad accident before I got it. It definitely needs some love. It has a 350 olds with a Camaro clip on it. The clip was on when it was in the accident it got bent pretty bad. It was pulled back to shape but it still doesn't drive straight . I've been looking for a 57-58 98 frame but I'm coming up with no luck . I've looked into using a different frame and the closest one I could find is a 71-76 B body GM frame. I found a 72 Pontiac Grandville convertible frame. The only thing is that this frame is a 1/2" shorter then the 58 frame which is 126 1/2 " long . I know it will be a big job, but do you think a 1/2" will make difference ? Hope to get some feedback on this . I would love to get this ol girl back on the road again. Any info or tips will be greatly appreciated.
This isn't just a "big" job, it essentially involves cutting the floor out of your current car and welding in the floor that matches the frame you plan to use.
eBay
Typed in 58 98 olds just now. Looks like someone is parting one out. Baby blue. Maybe he has a frame.
It's a four door though. Don't know if you could use it or modify it.
Thank you for all the replies. Just having trouble locating a stock frame. 57-58 98 2 door or 4 door should work . Thank you Gary M for the info I'm gonna call those guys up and see what they have. I know swapping frames is a big pain in the *** but if I cant find an original that's gonna be my only choice. I'm not giving up on this car I'm gonna do what I can to get her back on the road again.
oldsmobilty
September 27th, 2012 04:26 PM
sixty9olds
June 14th, 2011 06:43 PM
1969goatman
August 30th, 2010 07:44 PM
