Diver side quarter window question
Old August 27th, 2018, 08:05 PM
72455's Avatar
I need to replace the roller the rides in the track pictured below. Do I have to remove the regulator, or is there another way?
72455 is online now
Old August 29th, 2018, 08:16 AM
72455's Avatar
Allan, I have the body manual but there are SO many figures and illustrations for the rear quarter windows, I dunno which is which. Can you help me narrow it down?
Thanks,
Dave
72455 is online now
Old August 29th, 2018, 10:43 AM
Allan R's Avatar
Dave Turn to page 7-6.
Allan R is offline
Old August 29th, 2018, 11:47 AM
72455's Avatar
Thanks Allan. Does it matter which "A" style I have, and not sure, but do I have to remove the glass to put the roller in?
And on another note, are the lower tail light lenses interchangeable with either side?
72455 is online now
Old August 29th, 2018, 11:59 AM
Allan R's Avatar
It's close to the same. You have a 57 style quarter window. The sheet metal on the quarters is slightly different for the fastbacks.
I have a couple regulators in the shed I can check for you later today if that's ok?
Allan R is offline
Old August 29th, 2018, 12:01 PM
Allan R's Avatar
Sorry I didn't see this. Yes, interchangeable side to side, just not upper / lower. Don't forget to reinstall those inner lenses. They're also size specific but can fit either side.
Allan R is offline
Old August 29th, 2018, 12:12 PM
72455's Avatar
That would be great..not doing it today anyway .too hot..lol.
72455 is online now
Old August 29th, 2018, 12:13 PM
72455's Avatar
Inner lenses??
72455 is online now
Old August 29th, 2018, 12:44 PM
Allan R's Avatar
Yes, there are inner lenses that go inside the lenses. They look like this: One for each tail light.
Allan R is offline
Old August 29th, 2018, 01:40 PM
72455's Avatar
Ummm...mine seem to be MIA. Do I need them and what are they for?
72455 is online now
Old August 29th, 2018, 01:45 PM
Allan R's Avatar
They diffuse the light from the bulb over a wide area to give better illumination. Otherwise you only have one small point of light which is the bulb.
PM 442crzy (Nick) He can probably set you up with some. They are available from The Parts Place (New Old Stock) for $20 each if you want to go that route.
Allan R is offline
Old August 29th, 2018, 02:11 PM
Allan R's Avatar
Ok I looked at the regulators in the shed. I don't see any way of replacing those rollers without taking the assembly out.
Allan R is offline
Old August 29th, 2018, 08:31 PM
72455's Avatar
So that means the glass has to come out? And on the tail light diffusers Nick is hooking me up so thanks for the referral...once I get them is there a certain way they have to be installed?
72455 is online now
Old August 29th, 2018, 08:50 PM
442crzy's Avatar
The roller that runs up and down in the center of the track pictured is attached to the bottom of the 1/4 glass, let me see if I have a loose one, I will PM you Dave.
442crzy is offline
Old August 30th, 2018, 06:26 AM
Allan R's Avatar
They have line up slots to fit the lens. The smooth side goes to the lens. You'll see that right away. Glad Nick could help you out.
Allan R is offline
Don Roberto
March 11th, 2017 02:29 PM
Transman
June 7th, 2014 01:55 PM
RPMRestoAndCustom
February 11th, 2012 01:21 PM
oldsonharmont
January 2nd, 2012 12:33 PM
71KUTLASS
September 23rd, 2010 11:06 AM
Quick Reply: Diver side quarter window question
