Diver side quarter window question
Allan, I have the body manual but there are SO many figures and illustrations for the rear quarter windows, I dunno which is which. Can you help me narrow it down?
Thanks,
Dave
Thanks,
Dave
Thanks Allan. Does it matter which "A" style I have, and not sure, but do I have to remove the glass to put the roller in?
And on another note, are the lower tail light lenses interchangeable with either side?
It's close to the same. You have a 57 style quarter window. The sheet metal on the quarters is slightly different for the fastbacks.
I have a couple regulators in the shed I can check for you later today if that's ok?
That would be great..not doing it today anyway .too hot..lol.
They diffuse the light from the bulb over a wide area to give better illumination. Otherwise you only have one small point of light which is the bulb.
PM 442crzy (Nick) He can probably set you up with some. They are available from The Parts Place (New Old Stock) for $20 each if you want to go that route.
So that means the glass has to come out? And on the tail light diffusers Nick is hooking me up so thanks for the referral...once I get them is there a certain way they have to be installed?
They have line up slots to fit the lens. The smooth side goes to the lens. You'll see that right away. Glad Nick could help you out.
