69 442 trunk lid template
Old January 5th, 2016, 07:30 AM
berettass's Avatar
I have a dilemma with my 442 trunk lid that may not be worth fixing and can't find another one in good shape.
So I am hoping a kind person could make up a template for the 442 numerals and I can convert a cutlass trunk lid to a 442.
This is for a convertible if that makes a difference.
berettass is offline
Old January 5th, 2016, 11:36 AM
Chesrown 67 OAI's Avatar
there should be a diagram for these drillings in the assy manual? the holes are unaccessable from the underside. you must use the "push-in" style holders. Using the modern-day double sided tape is also an option. cut the prongs off and stick em in place?
Chesrown 67 OAI is offline
Old January 5th, 2016, 11:37 AM
convertible deck lids are different. you cant use a coupe decklid on a ragtop
Old January 5th, 2016, 05:13 PM
berettass's Avatar
The chassis service manual does not show a thing and the fisher body manual shows the numbers go on the trunk lid but that's it.
I know the lids are different but was not sure if the numbers would be in a different spot too...
I was hoping someone would put the layout on a 8 1/2 x 11 and I could just print it and set it on the trunk lid
Old January 6th, 2016, 07:40 AM
The two trunklids (and thus number placement) are the same at the trailing edge, since all 69s used the same back bumper and taillights. The differences are at the leading edge of the trunklid and don't affect the numerals.
Stupid question, but can't you make a template from the old trunklid?
joe_padavano is online now
Old January 6th, 2016, 07:47 AM
berettass's Avatar
Well, that's good to know...
I would have if I could but its all rusted away from an accident and bondo patch job, I bought another parts car 442 to find that trunk lid was a cutlass lid and the holes don't even work with the numbers
Old January 6th, 2016, 03:00 PM
Yellowstatue's Avatar
Check with John Green in Janetville. 70five 328 035nine He may have a lead for you. And watch out for that merry go-round.
Yellowstatue is offline
Old January 6th, 2016, 03:51 PM
berettass's Avatar
Thank you, I will give him a call... Not too far from me...
And you have been to Roseneath before I see..😊
Old January 6th, 2016, 06:41 PM
Also Sammy on this forum lives near Blackstock, check with him also. Was on my way to a car show in Norwood a couple years ago and saw your 100 year old merry- go-round. Was closed on that day.
Old January 13th, 2016, 09:27 AM
I have a good 69 442 decklid. I can mke you a template and pdf it to you to print out if you still need it. I still think there exist a line drawing for these. Ive seen it for the fender 442 embems. ( with or without bumble bee stripes). Let me know if you still need it.
Old July 16th, 2018, 12:53 PM
berettass's Avatar
Digging up an old post...
Anyone to help with a template?
Old July 16th, 2018, 02:20 PM
Chugger's Avatar
I can help. I made up my own template file a couple years ago when I had my car painted. I can send you both the files and pics of my car so you can see end results. Whats the easiest way to do this ? - Jeff
Chugger is offline
Old July 16th, 2018, 02:30 PM
Chugger's Avatar
I realize this is a fender template and not the Trunklid info you're asking about but I suspect others looking at this thread will be interested to see the image.
I used this pic to decide placement. To me it looks like the 442 is numeral width from the right edge and numeral height from the lip.
Chugger is offline
Old July 16th, 2018, 02:38 PM
Chugger's Avatar
Chugger is offline
bigdooly
August 14th, 2019 03:55 PM
Zr1bandit
March 5th, 2017 09:33 AM
armycav0
May 2nd, 2014 06:23 AM
russ0326
December 18th, 2013 07:45 PM
RALLYE KID
September 28th, 2013 06:12 PM
Quick Reply: 69 442 trunk lid template
